Originally Posted by misti
Great info here, thanks for posting. Andy is such a cool guy and able to explain himself very well.
Was there any one thing in the article or video that really stood out for you or that you think will make the biggest difference in your riding?
Misti
Most of his points are pretty good, although an experienced rider should already know all of them. The one thing I think he should have added is "look further ahead of you".
A couple of my friends have had problems with things happening "too fast" for them.. when we discussed it, it turned out that they were not looking far enough ahead and by doing so, everything was happening too quickly.. the road was "rushing" by, corners were arriving too quickly etc. Once they learned to look further ahead, everything slowed down for them.
If you are "looking" at the corner you are presently in, then you have not been looking far enough ahead of you. You should always be scanning ahead, your brain will figure out the best line through the corners ahead of you if you give it time and it kind of "remembers" the line it just saw a second or two before when you were scanning.
Looking further ahead also helps with road conditions, seeing debris before it becomes a problem, seeing wet areas, potholes etc.
Good stuff though.
