Originally Posted by randomwalker
Can someone explain how closing the throttle, trail braking, maintenance throttle and rolling on the throttle all work together with respect to the apex of a turn (if they do)?
trail braking is just as described "trailing off the front brake as you get deeper into the turn"
maintenance throttle: is used to take the slack out of the chain and tighten the suspension and chassis
rolling on the throttle is done to transfer the weight to the rear tire to maximize grip and to drive out or the turn after apex
and typically only "rolling on the throttle" is done after apex, the rest are before
is this what you were looking for?
