Originally Posted by KrautBurner
From what I have read it relates to the gyroscopic effect of the front tire trying to find center( auto correct ) but it oscillates too far. Basically when you are riding straight and both wheels are in line the bike will continue that way unless something is done to change the wheel track, like turning the bars. When you let got the wheels try and come back into line. If that happens too fast they can over correct and then they over correct back again but a little less. This continues until they come back into line. Sometimes they go into harmonic oscillation and the effect is magnified and it takes a good while to auto correct but most times you just have to relax and hold the bars loosely and let the bike correct itself. The steering damper ( hidden in the faring on the RR ) helps to reduce the violence with which the steering head moves and lessens the 'tank slapper' effect. Four wheel drive trucks use the same thing on the steering to keep ruts in the trail from ripping the wheel out of your hands. I would have to look up the exact definition but this is my understanding of why it happens. Lifting the front wheel off the ground in a wheelie and setting it down out of line just makes it happen very quickly. The more out of line you set it down the greater the effect.
This is a pretty good explanation, I just want to clarify something you said. You mention that the bike is stable and will continue following a line when the bike is riding straight but that if something is done to change the wheel track, "Like turning the bars," that the bike might try to auto correct.
Turning the bars won't initiate a tank slapper and the wheel won't try to come back in line if you have just turned the bike. It takes a greater force, like if you come down crooked after a wheelie or hit a big bump while leaned over that is going to initiate the auto correct response from the bike. Riders holding on too tight will also prevent the bike from auto correcting in this situation.
You guys mention relaxing on the bike but that can be pretty freekin hard to do when the bars are going from side to side in a frantic manner. What can you do with your body to help ensure that you are able to relax your arms and not strangle the bars?
Misti
