Keep in mind, these are really a universal rearset!
Quadratic Multisets Rearsets:
Infinitely adjustable carbon fiber rearsets from Double Dog Moto are an industry first. Due to the patented rotating and locking support arms these rearsets more adjustability than anything else on the market. Since the arms rotate independently, they also have the ability to fit a multitude of sportbikes with two point frame mounts (click for video on how this works). Available with or without levers (for sportbike models with direct levers) as well as with or without master cylinder mounts.
Double Dog Moto rearset brackets are made in our San Francisco facility by compression molding carbon fiber, resulting in an exceptionally strong and durable rearset weighing approximately half the weight of regular aluminum.
* High strength CNC 7075 aluminum control levers rotate on sealed bearings for positive movement.
* 7075 foot pegs are adjustable for position via eccentric rotation. Unequal rotating mount arms allow for infinite adjustability.
* Less weight than the aluminum equivalent yet far stronger and "crash-resistant".
* Comes with mounting hardware, control rods (where applicable) and brake lever pivots (for Ducati).
Solid shift:
In addition, they have revised the problematic long BMW shift linkage by incorporating a pivot point and lever into our own aluminum CNC machined sprocket cover. The result is a shorter revised linkage directly from the lever to the gearbox. Works with both stock and aftermarket quick shifters, and in GP or regular shift.
Bolt on convenience - replaces the stock front sprocket cover and has multiple pivot points for variable lever adjustment.
No cutting or modification of stock BMW bodywork needed.
