I do track Racing and sinds last race my bike wouldn't shift using the lever and the power shifter. The onlusten Way i can ride the bike is by using clutch and shift.
Does anybody know the cause of this issue?
there is a plastic piece on the bottom of the lever. make sure it is engaging the switch. when you pull the lever in you will here a click if it is right. If it does not click there is your problem. Otherwise maybe the switch itself is bad? search the forum there are several threads on this. My issue was adjustment.
I almost can't believe this. I had a bad day at the track last night. I just checked the lever this morning after reading your instructions.
I have a stuck lever however it was not clicking. I fixed this and the shifter is working perfectly!!! So it shurely was the microswitch issue.
Thank you very much guys!!
