S1000RR GSA(gear shift assistant) trouble. - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-19-2011, 12:04 AM   #1 (permalink)
Default S1000RR GSA(gear shift assistant) trouble.
HI.. i am korean. i can't speak english..i am so sorry....
11MY S1000RR GSA trouble..
after shift up with GSA..fixed gear pedal...on the top..
gear pedal is not return..
and throttle close..gear pedal is return..
why this happen??
again i am so sorry..i can't speak english..
i like s1000rrforum users :-)
please comment..i am waiting
korean choi pro is offline   Reply With Quote
Old 09-19-2011, 01:43 AM   #2 (permalink)
Nomad's Avatar
Sounds serious. Don't ride it until after having it checked. If a spring has broken it may damage the engine.
Old 09-19-2011, 02:21 AM   #3 (permalink)
Default thanks..
thanks nomad
but gear is well insert..
only..gear pedal is not return..
Old 09-19-2011, 11:04 AM   #4 (permalink)
Nomad's Avatar
I suspect there is a return spring on the shift mechanism inside the engine. I'm worried that spring is broken. If it's broken then the lever may not return correctly. If it's broken then you have pieces of steel spring moving through your engine. It may be something simple as well but I would hate to see your engine damaged internally. Have it checked.
Old 09-19-2011, 01:16 PM   #5 (permalink)
Possibly the gear selector shaft or detent spring-get it checked by the dealer.
gixerconvert is online now   Reply With Quote
Old 09-19-2011, 08:27 PM   #6 (permalink)
Default thanks.
always thanks Nomad
but.. it is Intermittent occurs. not always.
I will visit dealer when tomorrow.
but they very busy
Old 09-19-2011, 08:36 PM   #7 (permalink)
Default thanks.
thank you very much gixerconvert
but I don't know about parts..
i am stupid..
can anyone find me the problem parts in this picture
Old 09-20-2011, 10:08 AM   #8 (permalink)
9. Locking lever 23007716793
Zed03 is online now   Reply With Quote
Old 09-20-2011, 12:09 PM   #9 (permalink)
9-detent spring
1-selector shaft-on the picture,on the far end there is a spring loaded slider held with a spot weld which are occasionally suspect.
Speak to your dealer as you need to access these through the clutch case.
Old 09-20-2011, 08:27 PM   #10 (permalink)
Default thanks.
thank you very much
today visit the dealer
I'll remember locking lever
