To help you out, there are no special tools required other than a good torque wrench (which everyone should have) and a good set of metric sockets.
There are a couple of "pins" that keep the pads in the calipers, but they aren't threaded, and have self-actuating position locators. (Pull out, push back in).
The caliper "bolts" which hold the calipers to the lower fork & axle pieces are M10 x 65 hex heads and should be torqued to 38 Nm.
You will need to remove the calipers before you can release the pins.
Be particulary cautious of the backing plate thickness of the replacement pads you buy. Search is your friend.
Good luck.
PS: You should probably buy the service manual OR download it from this forum for questions like this.
On the street - 2/5/10.
