Originally Posted by H-2 CHARLIE
I made a soild peg board that i slide in between the hub and the swingarm ,when its on the stand getting sprayed with ... Dupont dry lube MULTI USE .
I don't suppose you have a pattern for that board or could you possibly post a photo of it? I currently stuff newspaper behind the chain to avoid spraying crud on the swingarm/exhaust.
I always clean the chain before lubing. Paraffin in a spray bottle for cleaning and then Wurth Profi-dry lube when it's dry. We can't get the DuPont stuff over here but it sounds like the Wirth stuff does the same job; goes on wet and dries invisible. Zero fling!
