First oil change - observations - BMW S1000RR Forums: BMW Sportbike Forum
Old 02-21-2010, 07:17 PM   #1 (permalink)
Default First oil change - observations
1) Yes, the bike is full of that diarrhetic break-in oil.
2) While you can get your hand in there from the left to get to the oil filter, it makes life much simpler to just pull the left lower. There's about nine screws all told, all in obvious locations and easily accessed with a T-25.
3) This is the first new bike I've ever had where the OEM filter wasn't *welded* in place. Much appreciated! My bike came with the 541 filter, but the dealer sold me a 779 as the replacement. I understand there's some debate about which is correct, I'm just reporting my experience. A "B" cap wrench will fit the 779, but the 541 uses some proprietary wrench. My oil filter vice grips made that a moot point.
4) Oil drain plug is easily accessible and again not overtightened. It has an integral magnet, and mine definitely had some metal on it, but nothing scary.
5) I don't see any way to get the filter out without making a mess. Probably the best way would be to make a little spillway out of foil to keep it off the headers; I tried with rags and failed. Ended up spritzing everything down with WD-40 and then Simple Green to get it clean in there.
6) Bike took just under 4 bottles of Castrol - don't remember if those were liters or quarts. Oddly, I never got a "low oil pressure" light even on first startup; most bikes I get that for two or three seconds until the filter fills and primes. I'm not complaining.
KeS
BTW - With the lower off, you can see that there are a couple of big-ass threaded holes in the engine. Don't know if those are there for installation, or what, but they certainly look functional.
Old 02-21-2010, 10:02 PM   #2 (permalink)
Holes are probably to mount on an engine stand when rebuilding and/or initial building as well.
Old 02-21-2010, 11:42 PM   #3 (permalink)
This is correct.
Part of the initial dealer equipment that got sent out contains the pin wrench for torquing the head bearing, an engine mount stand. service spools, and a clutch holding tool.
Marcusredmonkey is offline   Reply With Quote
Old 02-22-2010, 09:11 PM   #4 (permalink)
Also have 541 filter removed today off bike and dealer sent me the 779 filter to replace with, I have noticed the 779 is a little bigger filter also.some guys were saying in another thread the 779 was wrong??I
RLONE is offline   Reply With Quote
Old 02-22-2010, 09:16 PM   #5 (permalink)
snocompton's Avatar
The 779 is the proper filter.
snocompton is offline   Reply With Quote
Old 02-22-2010, 09:29 PM   #6 (permalink)
Ty for the quick reply,now I'm kinda glad I have a couple extra.
Old 02-22-2010, 09:41 PM   #7 (permalink)
snocompton's Avatar
They are pretty useful
Old 02-22-2010, 09:52 PM   #8 (permalink)
I have just a qucik question. If the 779 filter is the "correct" filter then why does the ETK that the techs use that was just released (02/2010) contain the 541 filter? Why does the webEPC that is an online tool available to dealerships contain the 541 filter? Why does the RSD tell you to use the filter wrench that is designed to remove the 541 filter? Please double check your informaton on which filter to use. The 779 filter was the filter originally placed in the information I recieved as well but it has changed to the 541 filter. For anyone reading this call your dealer and ask them to look it up if you are unsure. That is what they are there for.
Old 02-22-2010, 09:57 PM   #9 (permalink)
snocompton's Avatar
I work in a BMW parts department. The filter I was told to supply is the 779 and that is what I have been told since the begining. I will check again tomorrow but as everyone so far has been supplied with the 779 from their dealer and all the literature I have seen has called for the 779. I will check ETK again tomorrow and gladly post if I am wrong.
Old 02-22-2010, 10:07 PM   #10 (permalink)
Little tired of the arguing, so my solution in future will be to simply use a K&N 164 and to hell with BMW.
KeS
