So I called my local dealer today to check and just see what the cost were to do the first service at 600 miles. Although I have already changed the oil once already I figured maybe I should take it in and have them take a look cause my bike at 500 miles is making a few noises, valves are a little bit noisy and the brakes squeak and grind, so I thought OK I should just have them go through it and this is what the dealer told me.
600 mile first service will cost $350 which consist of changing the oil and filter, checking the steering head torque, adjust the chain and check all the fluids... OUCH!! Shouldn't need an initial valve adjustment.
Next service 6000 miles...
WTF??? Cost $300 and consist of changing the oil and filter, adjust the chain and check all the fluids and extra if it needs brakes.
3rd service 12,000 miles and $350 and consist of changing the oil and filter, changing the air filter, adjust the chain and check all the fluids
4th service is the biggie... $700 and consist of a valve adjustment, changing the oil and filter, checking the steering head torque, adjust the chain and check all the fluids.
So my final thought when I hung up the phone was first WTF is BMW thinking with the 6000 miles between the oil changes? I will continue like on my GSXR 1000 to change the oil myself at 100, 600, 1000, 2000, 4000, 6000, 8000 and 10,000 miles and so on. Oil changes will cost me $70 max! You cant have to clean of oil can you? Nope!!! I do all the fluid checks and chain adjustments every 500 miles. I just don't understand the justification of spending $350 for them to do a visual inspection when you should know how to do that anyways before riding your bike. No brake fluid could kill you, no antifreeze or oil could seize the engine and kill you, to loos or to tight of a chain could kill you, bold tires or poor tire pressure can kill you!
That's just my 2 cents!
