Clutch Nut Loose
I put a Factory Pro clutch spring in and did everything else per the manual. I borrowed my neigbours torque wrench as mine didn't go up to 150nm that the main bolt needs.
Anyway, this bike is a build up from a crashed bike to go onto the track. I havn't riden it anywheer but today ran it up and down my drive, just 1st and second gears were used.
After it had sat, I went to turn the bike on, pulled the clutch lever in and it was real soft and barely engaged the clutch. I turned the bike off.
I thought maybe the thrust bolt lock nut couls have come loose some how. Anyway, took the clutch cover off, the torue bolt was fine.
Took the spring and the plate retainer off and noticed that the main big collar nut was turned slightly out of the position where i punched the two sides into the detents 9to supposedly stop it rotating).
Anyway, i could turn the nut off by hand! This must be why the thing was out of adjustment.
I read the STM install and they say to torque that thing down with an air gun, oruse a torque wrench.
My question is: do you think it was just not enough torque?...this needs a lot I know and I am ordering a new collar nut. I used the old one before. Just wondering if maybe it wasn't enough.
Anyway advice would be great if any of you have some knowledge in this area.
CRA 75E
2010 #7 NOVICE
Reason: alter title
