Silkolene Pro 4 10/40 - BMW S1000RR Forums: BMW Sportbike Forum
Old 03-19-2011, 07:57 AM   #1 (permalink)
Fad-dad's Avatar
Default Silkolene Pro 4 10/40
My local bike shop only stocks Silkolene Pro 4 10/40 fully synthetic at £46.16 for 4 ltrs. Anyone tried it.
I've started doing track days so want to keep the internals nice and smooth, especially the down changes!
Thanks
Fad-dad is offline   Reply With Quote
Old 03-20-2011, 04:01 AM   #2 (permalink)
Nobby_Mike's Avatar
Send a message via MSN to Nobby_Mike
BMW recomends that you use only 5W/40 castrol power one, which of course, is only available from them.
I asked them if it would be ok to use 10/40 in the bike and they pretty much said no.
Although i have heard of people using 10/40 and other oils without a problem..
N O B B Y
Nobby_Mike is offline   Reply With Quote
Old 03-20-2011, 06:10 AM   #3 (permalink)
Fad-dad's Avatar
Yer, thats my problem. My head says its an engine, pretty much the same as any other, and that fully syn 10/40 will be fine. Reading through the threads no one seems to have had a problem with other oils. In fact I think I read that in some cases the gear box action improved.
I did a track day last week end, and found the box a bit clunky on down changes, so anything that helps smooth this out would be a bonus.
Those who have changed to 10/40 would you say:
Not so good...........no different..............slight improvement
Thanks, any advice would be great.
Old 03-20-2011, 09:52 AM   #4 (permalink)
RIQUE's Avatar
Check my oil thread on this forum. 10W40 Full Synth is no problem and also recommended on the user manual. Amen.
Life Rewards Action.
He who is not afraid is safe!
You get used to speed fast!
Panic is NOT a strategy!
Old 03-20-2011, 12:28 PM   #5 (permalink)
Wild Pete's Avatar
Fat-dad, I use Silkolene PRO 4 Plus 5w-40. Good stuff, but expensive. I usually order my oil on line from Opie Oils. 4 liters would cost you about £55.00 if you're not a member.
Wild Pete is online now   Reply With Quote
Old 03-20-2011, 01:07 PM   #6 (permalink)
Fad-dad's Avatar
Cool thanks, I think I'll give that a go.
I might need to start another thread on when to change the oil if you are doing track days. I was thinking I might need to change it after every 3. I'm not pushing it that hard, so I think thats often enough?
Thanks for the Opie Oils tip.
Old 03-20-2011, 07:43 PM   #7 (permalink)
cloudy's Avatar
Default BMW Recommendations
The following is copied from the Shop Manual, and says 10-40 is OK fwiw:
http://www.s1000rrforum.com/forum/at...1&d=1300664263
Silkolene Pro 4 10/40-bmw-oil-recs.jpg
