Key Barrel Sticky - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-20-2010, 12:16 PM   #1 (permalink)
Default Key Barrel Sticky
We have suffered from bad weather the last few days and the key is starting to get a bit tight and sticky in the barrel, is it ok to use clean engine oil to help free things up?
markys is offline   Reply With Quote
Old 11-20-2010, 12:24 PM   #2 (permalink)
Toynut's Avatar
I would recommend you go to a locksmith or a hardware store and get some lock fluid with powdered graphite in it. That is generally the traditional remedy.
An example:
http://www.agscompany.com/lubricants/homehardware/179
Old 11-20-2010, 01:01 PM   #3 (permalink)
Dshred's Avatar
If you have any, a drop of DuraLube will work. It free's up the lock on the house when it gets jammed up.
Old 11-20-2010, 03:48 PM   #4 (permalink)
H-2 CHARLIE's Avatar
any grease will work fine i use syn bearing stuff .
SO.CAL.we ride all year long
