Originally Posted by dePunietS1000RR
Could not find a thread on changing the brake fluid on the ABS version.
I am about to put a new master cylinder and want to take advantage of that to replace the original brake fluid with Castrol SRF.
People told me that all I have to do is bleed the front (both caliper and master cylinder) and then bleed the rear. I just want to make sure that I don't leave old brake fluid in there and bleeding front and rear logically seems to miss fluid that would be on the circuit that activates the rear brake when you pull the front brake. I tried to see if the rear wheel would stop when I pull the front lever and it doesn't (with the bike on or off).
Any advice would be appreciated.
When I changed my master cylinder to the Brembo Rcs I just drained all the fluid out of the reservoir and drained as much as I could out, the only way to know if you got all the old stuff out is to run a different color like the ate blue brake fluid and switch from gold to blue, but I heard it stains your reservoir a little.
Just see how much you can get out, but a little left in there wont hurt your performance, I have done 3 track days and didn't have any fade the first time I went out with the stock master cylinder and brakes, so I don't think it will be a huge advantage, but I'm not Rossi either lol (but i do high 30s at fontana) so I'm not that slow either
if you want to get it all out I would drain it and then ride it around for like 15 -20 mins and then drain it again
hope this helps,
Sl8R
