torque settings - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-06-2010, 10:36 AM   #1 (permalink)
r1blade's Avatar
Default torque settings
HI,can any one tell me the torque settings (nm) for the rear sprocket nuts,i,m replacing them with titanium ones and it said set to manufact/setting .thanks
r1blade is offline   Reply With Quote
Old 09-06-2010, 02:29 PM   #2 (permalink)
Rodomontade's Avatar
Originally Posted by r1blade View Post
HI,can any one tell me the torque settings (nm) for the rear sprocket nuts,i,m replacing them with titanium ones and it said set to manufacture/setting .thanks
Service Manual Quotes:
110 Nm or 81.061 FT/Lb
I don't suffer from insanity.
I enjoy every minute of it!
Acid Green S1000RR 2010
Copper Hayabusa 1999
Rodomontade is offline   Reply With Quote
Old 09-06-2010, 02:33 PM   #3 (permalink)
r1blade's Avatar
thank you, think this forum is great!
Old 09-07-2010, 12:08 AM   #4 (permalink)
That is the axle nut torque. He is talking about the bolts holding the rear sprocket to the sprocket carrier.
I think it is something like 40NM--don't quote me on it but it ain't 100.
Old 09-07-2010, 02:00 AM   #5 (permalink)
Rainman's Avatar
Sorry Viper, I think this dude is right. This is straight from the RepRom in both the Service Data and Tightening Torque sections.
Service data 0517 - S 1000 RR
Equipment trim-level variant:
0129
BMW Motorrad Race ABS and DTC
Chain sprocket to chain-sprocket carrier
M12 x 1.5 - 10, Replace nut
Mechanical thread lock
tighten in diagonally opposite sequence
110 Nm
On the street - 2/5/10.
Rainman is online now   Reply With Quote
Old 09-07-2010, 07:44 AM   #6 (permalink)
Nope that is correct info right out of the BMW SERVICE MANUAL!
It is for the nuts that hold the sprocket to the carrier.
If I post, you can bet your ass it is correct info based on current information.
Old 09-07-2010, 10:23 AM   #7 (permalink)
Godzilla's Avatar
Would be very helpful if someone can look up the torque setting for the bolts that attach the frame sliders.
TIA
Old 09-07-2010, 10:29 AM   #8 (permalink)
Frame Slider Bolts - Torque ?
Old 09-07-2010, 10:35 AM   #9 (permalink)
Rear sprocket to sprocket carrier - 110Nm --> Go to Post #4 -->Torque Specs and then click on "Rear Axle, Rear Wheel Drive and Rear Wheel Guidance"
Old 09-07-2010, 11:19 AM   #10 (permalink)
My bad. Haven't really changed them much yet. That is higher than on the other BMWs with chains but in the S's case it is a much larger sprockey/carrier and chain.
