Chain cleaner: Yes? No? Maybe? - BMW S1000RR Forums: BMW Sportbike Forum
Old 08-15-2010, 05:55 PM   #1 (permalink)
Default Chain cleaner: Yes? No? Maybe?
Specifically, this thing: Deluxe Chaindrain Kit
It's been almost 2,000 miles and yet to be cleaned (since new). Maybe a spray can oiling every 500 miles - or whenever I feel like it.
Messy chain cleaning ain't on my high-priorities list. Maybe this contraption would help?
Mack
Old 08-15-2010, 07:13 PM   #2 (permalink)
Toynut's Avatar
I have one of their kits and it works quite well. Their cleaner does a good job but you will probably use one can per session if the chain is really gritty (particularly if you use the sticky waxy type of chain lube). I would order extra cans for future use. I still place a piece of cardboard underneath the left side of the bike just in case I get a bit to loose with the spray lube.
Review of the product:
Chain Drain Chain Cleaner Chain Cleaning System- webBikeWorld
Try Dupont chain saver lube with Teflon. It works great and won't pick up too much street crud in the links.
Write up on it:
DuPont Teflon Chain Saver - DuPont Teflon Chain Lube - webBikeWorld
Old 08-15-2010, 08:30 PM   #3 (permalink)
crabman's Avatar
I know we all have our different ways of doing it but for me I use kerosene based engine cleaner. With my bike up on a stand spray the cleaner on the chain as it runs over the sprocket. I use the same brush they use in the above review and then spray it again. Rinse it with water, wipe it dry and then use WD-40 to displace the moisture, wipe off the excess. I let it sit for a few hours and then ride it for a couple miles bring it home and put PJ1 Blue label on it and let it sit overnite. Works well for me, I do this about every 3K miles.
Jim
2010 Thunder Grey
crabman is offline   Reply With Quote
Old 09-01-2010, 03:29 AM   #4 (permalink)
I am agree with chain cleaner.I use degreaser or kerosene to clean the chain and rims. its best to do it in a pure stand, if you can clean kero tires with soapy water to ensure that you do not have a soft patch
holliebibi is offline   Reply With Quote
Old 09-01-2010, 01:47 PM   #5 (permalink)
DrIoannis's Avatar
I clean it with kerosane every 600km and lube it every 300km...
Old 09-01-2010, 02:39 PM   #6 (permalink)
H-2 CHARLIE's Avatar
I use kerosene like the manurfacture says ... a rag extra damp but not dripping all over every 1000 miles ,then dupont teflon dry wax after every ride, dry rag wipe then spray teflon .... im due now for a kerosene cleaning . The cut board between the frame & rim keeps the mess off the rear rim .
SO.CAL.we ride all year long
Old 09-01-2010, 02:44 PM   #7 (permalink)
shashankmittal's Avatar
Kerosene is good, but I prefer Motorex chain clean. It works better and does not leave a mess.
// 2008 X5 Black
Old 09-01-2010, 05:47 PM   #8 (permalink)
i use tirox chain cleaner and then use rags to wipe clean,then dupont teflon chain saver.
Prowler is offline   Reply With Quote
Old 09-02-2010, 07:11 AM   #9 (permalink)
R1HOOLIGAN's Avatar
Every 500 miles or so I blast the chain with WD-40, wipe it down good and then apply a lubricant such as the aforementioned Dupont lubricant. The chain is the most ignored part of the bike. If you keep it cleaned/lubed/adjusted, the chain (and sprockets) will last quite a long time. I've gotten as much as 15K miles out of a chain. Remember, always change the chain and sprockets at the same time. Maintaining your chain will save you a wad of cash.
Current Garage Inhabitants:
2010 S1000RR - White/Blue/Red
2008 Honda CBR 1000RR
2008 Kawasaki ZX-10R
2006 Suzuki GSXR 1000
2008 Suzuki M-109R LE
2008 Kawasaki Teryx
R1HOOLIGAN is offline   Reply With Quote
Old 09-02-2010, 10:06 AM   #10 (permalink)
