Don't loosen or move the left side fork bolt, if you do you could ruin the sensor which needs to be a specific distance from the wheel, if you don't unscrew or move it, you shouldn't have a problem, so in other words, don't even loosen the pinch bolts on the left side.
The axle slides out to the right of the bike, may take a "slight" tap with a hammer to get it started.
Hope this helps,
Michael
