Originally Posted by kevin_stevens
I've had the rear wheel off half a dozen times now for various reasons, and that self-locking axle nut is just tearing up the axle. I've been using anti-seize on it, no power tools, and it isn't obviously stripping or crossthreading, but it's just very hard to turn throughout the travel, and clearly tearing up the axle threads. I'm now at the point where I'm concerned that I may be looking at buying a replacement axle and nut for my next tire change, which is likely to be hideously expensive.
Anyone have a different experience - like is your axle nut just spinning off and on by hand? I wonder if I just got a bad nut, but the dealer is going to think it's not a warranty issue at this point.
KeS
Bummer. Are you sure the threads on the axle are suffering? I've had these things be damn hard to turn throughout their locking travel, but the threads on the axle seem fine. So I wouldn't be terribly concerned if the only symptom is having to work to turn it.
If the axle threads are truly suffering, it sounds like the self-locking compound is just wearing out the threads. Maybe the self-locking part is just too aggressive or you have one with bad tolerances. I'd go ahead and replace the nut now rather than risk having to replace the axle. Or how about putting a regular thread nut on there and safety wiring it? (Or even drilling out the axle for a cotter.)
I wish the mfgs would stick to conventional axle nuts, drilled axles, and cotter pins. Simple, safe, no wear issues. If you don't want to screw around with one-time use cotters, you just buy one of those spring-loaded jobbies.
