Originally Posted by Waeltken
Hey guys,
I did my 9000 mi oil change and accidentally poured a little too much oil in the reservoir. Basically with the bike cold and on a rear stand the viewing glass shows about 90-95%. After warming the bike up to operating temp, putting it on the rear stand and letting the oil drain back into the reservoir, the glass is completely full (no line visible). I take it that's too much.
Is there any other way to cleanly extract 0.2-0.4 L from the oil reservoir than opening the drain screw again? Is there a way to siphon the excess oil out from the top using a pump or something?
Thanks,
- H
yes...use a pump like you said, or get a big syringe and some tube. Did you tip the bike a little to see if you were just barely over the line?
Although for the record I would call that good if its showing below the line cold, but that's just me.
