Originally Posted by jovie
I've recently replaced my front pads with Brembo RC's.
I've done this before loads of times on bikes and cars and this one was pretty straightforward, however the brakes now feel slightly spongy even though there was a lot of fluid in the MC when i replaced the pads so air could not have got in, in fact I had to syringe out some fluid to return the level to max.
I've only ridden it about twenty miles since but i'm sure the brakes aren't as sharp as before.
Should I just bleed them anyway or is there something else gone wrong?
Some types of pads need a specific break-in. Try this:
Find a deserted piece of road (or a track) and get the bike up to 70 mph; use medium pressure to brake the bike down to 25 mph or so.. repeat 5 times in a row, fairly quickly to get heat in the rotors.. after a few more seconds, get the bike up to 90 mph and try braking moderately hard.. See if that helps
Another issue, could be with the rotors .. they will have a wear pattern in them from the previous pads and it can take a while for new pads to wear to match your old rotors.
