All controversial subjects that are discussed for hundreds of pages on this and other motorcycle forums....
Originally Posted by usrodeo4
first what engine oil does BMW recommend? If it isn't synthetic are people running synthetic? I assume the race teams run synthetic like the Hipo cars? Any personal experiences with synthetic? What weight? I hear the latest 0W-xx synthetics have amazing lubrication qualities, even at start up.
I'd use what BMW recommends, 5W-40 or 10W-40, full synthetic. Probably comes from the factory with this. BMW sells their own or you can go aftermarket, but I'd stick to full synthetics, not blends. And while under warranty, I wouldn't experiment with car oils or varying viscosity - stick to motorcycle-specific, full-synthetics of the correct viscosity. If you change your own oil, keep good receipts and log the maintenance. If you have the shop do it, they'll probably use the BMW stuff.
What is the prescribed chain lubrication process/schedule? What lubricants are recommended? Do you need a stand to tighten the chain?
I'd check tension every 500 miles or so. If it goes longer, probably not a big deal though. Don't overtighten - more chains are probably worn out prematurely due to over-tightening than under-tightening. Whether it needs adjustment is mostly a function of how hard/abusive you are with the bike, but unless you're a holligan, you won't find it needing adjustment very often.
With modern o-ring chains, frequent cleaning/lubrication is not really required to get acceptable chain/sprocket life, although it never hurts and will extend chain life. Personally, in the shop, I like to clean the chain with WD40 and then use 90W gear oil. On tour, I use some of the aerosol stuff, but I don't use it very often, especially if the weather is dry.
You don't need a stand, but it makes the job much easier.
I assume the S1RR takes premium fuel...is that true? Any issues with 93 octane w/up to 10% ethanol? (That's typically what we get here in Central Florida). Just out of curiousity can it run 87 octane without detonating?
Officially, it requires 89 pump octane which is mid-grade in most markets. The bike has knock sensors so you shouldn't suffer any engine damage using less, although performance may suffer in demanding octane conditions (e.g., big throttle openings, low RPM, high ambient heat, heavy loads). I generally use whatever the gas station is selling that is >89. I'm not a believer that using extra octane in a bike not designed to take advantage of it has any benefit.
BMW says up to 10% ethanol is fine. E10 is now almost the only fuel available in most markets so it is being used universally so the bikes seem to be tolerating it fine. I do prefer non-ethanol if available, but I don't go out of my way to find it.
In general, if in doubt, follow the book (owner's manual).
