Hi all,
Maybe some of you BMW mechanics or race prep guys can help me out.
I had a low side at the track this last fall, and when I went to replace the right side frame slider
I noticed the un-threaded "bushing" in the frame was split. I can't tell if the fall did it, or it comes split like this.
Here is what it looked like:
There are some rough edges on the frame, but the frame itself looks OK. (I took the gilled siding off and took a good look at it then).
Here is a parts schematic of the front frame. I've pointed out the two pieces that look like they are designed to be replaced if needed.
Part 10 is called a "Ball Element" and part 11 is called an "Expander Sleeve".
Does anybody know if my sleeve is OK or whether the sleeve can be easily replaced without removing the engine if needed? The REPROM suggests it can come out with the bolt. Would it normally slip out the right side or is it pressed in, or how is the ball element involved with it?
Thanks for any experienced insight.
