3rd Service 12,000 Miles cost - BMW S1000RR Forums: BMW Sportbike Forum
Old 12-05-2011, 09:34 AM   #1 (permalink)
Outlaw's Avatar
Default 3rd Service 12,000 Miles cost
3rd Service 12,000 Miles cost?
I hit the 12,000 miles on my S, how much is the cost? I also need to do front brakes
Outlaw is offline   Reply With Quote
Old 12-05-2011, 11:43 AM   #2 (permalink)
shashankmittal's Avatar
It should cost you around $220. If you change the oil yourself, you can save about $50. The 12k service includes bleeding the brakes, which your dealer will do unless you tell them otherwise.
// 2008 X5 Black
Old 12-05-2011, 12:30 PM   #3 (permalink)
Banned
Another thought that if you are going to be bleeding the brakes is to change the fluid out for Motul RBF 600, a racing high temp fluid. My brakes started feeling "spongy" after a while and switched to this (also recommended to me by the BMW dealership) and it made a world of difference. Costs a bit more, but is well worth it!
AlienRunner is offline   Reply With Quote
Old 12-05-2011, 12:31 PM   #4 (permalink)
+1, RBF 600 is the way to go, it made a big difference for me too!
// 2008 X5 Black
Old 12-05-2011, 01:38 PM   #5 (permalink)
If you're going by the book, a 12K service is essentially the same as the 6K service: oil change, air filter change, and a bunch of checks. So whatever you paid for the 6K should be about right.
Brake fluid changes are a year after new, then every two years.
The big hit comes at 18K when you have to check the valves, change spark plugs, and change the fork oil.
