Starlane GPS Laptimer (Slightly Used) ... Only $269 - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > Supporting Vendors > HardRacing.com
Old 07-05-2011, 02:58 PM   #1 (permalink)
Site Sponsor
HardRacing's Avatar
Default Starlane GPS Laptimer (Slightly Used) ... Only $269
It's not very often we have something like this. But, one of our Guys wants to upgrade his laptimer to the Full Digital Dash.
So we are offering this Slightly used Starlane Stealth II GPS Laptimer for only - $269
That's nearly half price off Retail.
It's in great condition. Works Perfect.
Here is EXACT Photo of the product.
Click here if you would like to order it.
http://store.hardracing.com/cart.php?target=product&product_id=21268&category_ id=825
We only have 1. So first come First serve.
1) GPS RECEIVER AND ANTENNA BUILT IN THE INSTRUMENT:
the Stealth shock-proof ABS body accommodates the GPS receiver and the relative antenna. This solution can make it really handy and simple, not requiring the installation of any additional detail on the vehicle.
2) YOU CAN SAY GOOD-BYE TO ALL UNPRACTICAL INFRARED TRANSMITTERS ARRANGED ON THE PIT WALL:
the use of the GPS system intended to detect the lap time will make STEALTH GPS-2 completely autonomous, requiring no beacon transmitters, such as the infrared ones used by old-generation systems.
Everything is getting much simpler. It is no longer necessary to arrange the transmitter and to recharge the battery, which is extremely annoying and unpractical, with the risk of forgetting it on the wall or having it stolen.
3) MANAGEMENT OF THE FINISH LINE AND 3 INTERMEDIATES:
just press one key to set up the coordinates of 4 finish lines (main finish line + 3 optional intermediates) during the first lap. Whenever you cross a finish line or an intermediate, STEALTH GPS-2 will indicate the relative drive-through time and store its value. You can therefore quickly evaluate your own performance even if you are driving along a part of the track far from the main straight stretch, which would be expensive and unpractical if you used any other type of chronometer.
4) INDICATION OF THE ACHIEVABLE IDEAL TIME:
by managing intermediates, STEALTH GPS-2 can calculate the time a driver can ideally achieve for every single session. This function is obtained by adding the best sectorial times. This will help you understand the lap time you might have achieved if there had been no traffic in a specific point of the track or if you had done a lap on top of your absolute performance.
5) DOUBLE FUNCTION "BEST LAP" LED:
the "BEST LAP" LED will turn on if you have improved your previous lap and it will blink if the lap you have just done is the best of the session. This solution will supply the driver with all the information necessary for performance without any distraction.
If you have set up intermediate finish lines, the LED is also enabled whenever you cross an intermediate. This means that this instrument is extremely useful to realise without any distraction whether you are improving compared to the same intermediate time of the previous lap or whether you have just accomplished the best intermediate time of the session.
6) GPS SPEED MEASUREMENT:
the advantage of using a GPS system is also that you can measure the vehicle speed with the highest degree of accuracy without having to install any sensor on the vehicle. No user setup is required and, above all, any measurement is always accurate, not altered by the inclination of the vehicle or wheel skidding.
7) DOUBLE HOUR METER FOR THE PERFECT PERIODICAL MAINTENANCE OF THE VEHICLE:
STEALTH GPS-2 has also got two hourmeters that can be separately reset for the periodical maintenance of the vehicle. Hour Meters are activated to receive the GPS speed signal. This solution can operate the hour Meters without any connection to vehicle harness.
8) BLUETOOTH STEALTH GPS-2 communication module with the computer in order to download the data that will be analysed, filed and printed by means of the DigiRace-LE software.
ALSO can also be upgraded for Future.
9) THE DIGIRACE-LE SOFTWARE:
it's always possible to download from the website the DigiRace-LE software that can file, analyse and print the data acquired and graphically represent the paths you have driven across with the relative acceleration and deceleration points for a lap-by-lap comparison.
10) 999-LAP MEMORY WITH AUTOMATIC MANAGEMENT OF 99 TEST SESSIONS:
STEALTH GPS-2 will automatically create a new session whenever you access the track. This means that you can analyse the times you have stored during the various sessions even at the end of the day without having to delete memory whenever you access the track. You can store the Date and Time of every single session as well as the total time, the intermediates, the maximum speed, the max. engine revolutions and the engine speed at the max. speed for every single lap.
11) STORAGE OF THE FINISH LINE COORDINATES OF THE TRACKS MOST USED:
you can store the coordinates acquired for the finish line of the tracks you are training on most frequently. You can file up to 16 tracks and easily call the finish line of the current track without having to reset it every time.
12) STEALTH GPS-2 IS COMPLETE WITH A BACKLIT LARGE-SIZE GRAPHICAL DISPLAY:
this solution has provided for the development of a software unit that can analyse all stored data and set up all wished functions in an unequally user-friendly and immediate manner. The display is of a transflective type, which means maximum visibility also in the sunlight when backlighting is off.
13) EXTERNAL SUPPLY:
supplied by 12V vehicle battery or by optional cases for 9V batteries or optional batteries. Moreover, STEALTH GPS-2 is complete with powerful energy saving and self power-off functions the user can set up to make the best use of battery performance. It is supplied with a specific extension with eyelets for battery connection and with a connector on one side of the instrument for rapid disconnection.
14) WATER-PROOFNESS:
STEALTH GPS-2 is waterproof and it can also be used in case of rain.
Specifications:
Automatic chronometer with 1/100 second resolution
GPS detection system with aeronautical algorithms
Calculation of the achievable Ideal Time
Calculation and visualization of 3 Intermediates
Digital speed indicator
GPS speed indication
Max. speed = 350 Km/h or 218 Mph
Double hour counter for engine maintenance
BLUETOOTH data download
Memory of 999 laps that can be managed in 99 sessions
Storage of max. speed values for every single lap
Speed indication in Km/h or Mph
Settable self power-off
Settable energy saving functions
122x32 backlit graphical display
Waterproof
Dimensions: width 90 mm - height 45 mm - depth 18 mm
Supply: external vehicle 12Volts or optional 9Volts battery cases or optional batteries.
Universal installation· DigiRace-LE software available for download
Intended use: car - motorbike - scooter - kart -ATV
HardRacing.com - 704-799-2192
>> S1000RR PROJECT BIKE BUILD <<
BIGGEST OHLINS SALE EVER .
Offering Great Prices, Tech_Support, Full Staff of Sales Reps, Fast WORLD WIDE Shipping, Large Inventory and Excellent Customer service.
Become a Facebook FAN, Click "LIKE" Button to get Exclusive SMOKIN' Deals
Celebrating our 13th year in business.
HardRacing is offline   Reply With Quote
Old 07-05-2011, 03:25 PM   #2 (permalink)
I'll take it.. And bought
Old 07-05-2011, 03:47 PM   #3 (permalink)
Site Sponsor
HardRacing's Avatar
SOLD. Thanks Man.
Old 07-05-2011, 05:17 PM   #4 (permalink)
Thanks! I look forward to using it on my next track day.
Old 07-05-2011, 06:06 PM   #5 (permalink)
Site Sponsor
HardRacing's Avatar
No problem. You will love it.
It's awesome to have LIVE Lap times, while your riding, and not have to worry about Transponders... and all that.
PLUS, the Data you can review afterward on your laptop is very helpful to analize where you doing well, and where you need to improve.
Amazing little device.
Old 07-05-2011, 06:57 PM   #6 (permalink)
I had purchased a little GPS enabled video camera, so that and this should just be awesome for analyzing how crappy I ride!
Old 07-06-2011, 11:58 AM   #7 (permalink)
Site Sponsor
HardRacing's Avatar
........ should just be awesome for analyzing how crappy I ride!
LMAO
Old 07-06-2011, 02:35 PM   #8 (permalink)
And for the record, in case anyone reads this thread, Hardracing went above and beyond.
They mentioned a couple things to do to make it easier to switch between bikes and to download the software beforehand.
All of that without asking.
Thanks guys! Can't wait to play with it this weekend.
Old 07-06-2011, 06:58 PM   #9 (permalink)
Site Sponsor
HardRacing's Avatar
Thanks Man.
Glad we could help.
Old 07-06-2011, 07:45 PM   #10 (permalink)
Spd_Dmn's Avatar
Damnit, can we just close this thread?! I keep thinking I have another chance lol. I missed one hell of a deal here!
Spd_Dmn is offline   Reply With Quote
