I pulled out all 8 injectors to run them through a test and clean at work. I don't see a filter in the top. I'm trying to figure out what, if any, filter to put in. Kinda scary if they run without filters! Anyone else had their injectors out?
The fuel filter in the fuel tank filters the fuel. There is a screen for larger particles on the bottom of the pick-up (before the fuel pump). Not sure why you want to put filters in the injectors as well.
I flowed and matched injectors for my F4i and I regularly clean and test boat and car injectors. They all have had some sort of screen in the top of the injector. Never seen one that didn't have a screen.
I doubt it would hurt if you could fit one in there if you wanted. The flow would be the same being the fuel is a liquid under uniform pressure in the system--fuel rail.
