Austin system and PCV V - BMW S1000RR Forums: BMW Sportbike Forum
Old 07-14-2011, 10:44 AM   #1 (permalink)
Default Austin system and PCV V
I recently fitted the ARCS system and a PCV V to my bike , the PCV already had a map which had proven good results for the previous owner.
I noticed this morning on my thrash to work in the sunshine that if I wait till the tacho is above 10-11K beofre shifting I sometimes have a huge lag before the power kicks back in ,it feels as if the bike hasnt quite changed gear but it has , below this rev range it all works fine.
I really need to get it mapped to my individual bike , however I just wondered if anyone else had encountered an issue similar to this
thx in advance
fatbob is offline   Reply With Quote
Old 07-14-2011, 11:36 PM   #2 (permalink)
thx in advance
other than your current issue, have you had any other issues with the austin GP3 exhaust?
LKSCNBDCVN is offline   Reply With Quote
Old 07-15-2011, 03:06 AM   #3 (permalink)
Nope I have not , I don't consider the issue I have to be any thing to do with the system either, I am sure it's either a QS issue , PCV map issue , or user error.
The system is the dogz danglies.
Old 07-15-2011, 12:46 PM   #4 (permalink)
Are you using one of the AR-CS maps provided from Austin? I don't have that problem at all that you describing.
Humtek is offline   Reply With Quote
Old 07-17-2011, 04:40 PM   #5 (permalink)
Neo
Neo's Avatar
thx in advance
Do you have the GP3 map? did you get the PCV from us?
www.austinracing.info
Neo is offline   Reply With Quote
Old 07-18-2011, 07:32 AM   #6 (permalink)
mik1000rr's Avatar
i know what you talk about , i had the same bug whit that map(m12-012-001)... in second gear at 9k rpm when i pulled it wont take the fuel cuz way to lean and dangerous !!!careful when you choose a map it can cost you an engine !
now whit the austin map( m012-012-006) and work great
btw im 100% stock only pcv
mik1000rr is offline   Reply With Quote
Old 07-20-2011, 07:50 AM   #7 (permalink)
thanks for the info , got the map off austin.
