PCIII vs PCV - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-30-2011, 09:59 AM   #1 (permalink)
Default PCIII vs PCV
Is it the PCV's size that makes it the better choice over the PCIII? We dont have too much support in the way of Bazzaz here in Australia (yet) or not that I know of.
Wondering which option to go with at the moment as I have a full akra system in the pipeline and would like to have the SKRR mapped after fitting the pipe...
What other add ons are good to have. Dont know to much about auto tune but i take it its named that for the obvious....
Thanks
JB_77 is offline   Reply With Quote
Old 05-30-2011, 10:20 AM   #2 (permalink)
The autotune functions as you ride, and if you have a switch hooked to the PCV, you can turn it off and run your map. I believe the changes made by the Bazzaz autotuner have to be accepted before you can use them, which means hooking up your computer to device.
The autotune will trim on the fly based on parameters you set. If it needs to trim out of your parameters, you have to accept the trim levels in to your map, and then run it again and it will re-trim. This would only really happen in you were running the wrong base map.
This is all stuff I picked up along the way, could be hearsay and conjecture for all I know. Hopefully someone chimes in to confirm/refute.......
ajfreeze is offline   Reply With Quote
