PCv and loading maps - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-12-2011, 04:10 AM   #1 (permalink)
diverbelow's Avatar
Default PCv and loading maps
Hi guys
Will be mounting my Pc into my bike this week end but I am wondering if I can Pre load the right map before installing the pcv?
As I won't have a computer where I will install the PC
Let me know if possible ?
Cheers
Old 05-12-2011, 09:08 AM   #2 (permalink)
Since you don't have to have the key on for the PCV to power up (the USB will power it up), I believe you probably could. You just need to load the software onto some computer somewhere and hook the USB up to it and it should power up. I have never tried it. Some PCIII's needed the ignition on to power it up... the PCV powers up w/the USB.
Old 05-16-2011, 06:05 PM   #3 (permalink)
Porridgewog's Avatar
What 1000RR said. You can use any pc with a usb connection to pre-load a map before you install it. The software's on the disk it comes with.
Porridgewog is offline   Reply With Quote
Old 05-16-2011, 11:01 PM   #4 (permalink)
koolcaymancops-S1krr's Avatar
Real easy to do with the included software, just DL the map you want on your computer then connect the PCV by USB and load it. It can be tricky so make sure you understand the difference between load and send, you have to send the map to the unit for it to load.
koolcaymancops-S1krr is offline   Reply With Quote
