Don't know, somethings wrong as mine is as sweet as it could be on and off the throttle.
Did you zero the throttle on the PCV? you need to be carefull doing this as it can not be set at 100%, are you sure the correct wire is attached to the throttle?
Hook it up to a PC and watch the throttle, it should show 3 or 4% before you start it and go to zero once started.
Are you sure the A/T is correct? and you have disconnected the original lambda sensors?
It's not just down to the fact that your running in slick mode or soemthing to get the bike to wheelie?
I also have no values in the zero column
