Akrapovic S-B10R1-ASZ - BMW S1000RR Forums: BMW Sportbike Forum
Old 04-21-2011, 06:23 PM   #1 (permalink)
Banned
Default Akrapovic S-B10R1-ASZ
Has anyone installed one of these systems on their bike that could give me some input?
Is there any factory info about the DB level?
Is a DB killer available from outside sources?
Has anyone been DB shot at a track?
I need help with this one please.
This is the full shorty system stainless headers and a can that looks like the factory one.
Thanks
KWAK is offline   Reply With Quote
Old 04-21-2011, 06:42 PM   #2 (permalink)
Richard5's Avatar
have a look at sponsor evoluzone cyclesports under sf 1000rr-evo its got headers with standard muffler on it
Richard5 is offline   Reply With Quote
Old 04-26-2011, 10:38 AM   #3 (permalink)
Scott Parker's Avatar
Thanks
Lots of people on here have that system ( well, the titanium one )
no db killer, unless you want to make something and stuff it in there ( i personally hate db killers, whats the point of going for a performance exhausts then shoving a baffle up its arse
It's about 108db at a static 5500rpm
i use an Austin Racing slip on link pipe to fit to my Akra pipes and a bigger Austin can for my track days
Scott Parker is offline   Reply With Quote
Old 04-26-2011, 01:02 PM   #4 (permalink)
Nigel's Avatar
I'll tell you something else about the pipe. Common view is that it is about a hp short of the long version, but mine is now making 2 hp more than all the other long pipes. Could be the engine but could also be that the a/f is now right for the pipe at this altitude.
N.
Old 04-26-2011, 02:30 PM   #5 (permalink)
Banned
N.
I am not interested in a 1 HP gain at the top end that even Troy would not notice.
If that were the case a system that costs more than $800 than this one would be very expensive per HP. $800 Plus per 1 HP gain.
I want the stock look but the DB level is to loud for some tracks and the street.
Most people would be better off trying to lose 10lbs than gain 1 HP
How much does a 10lb loss equal in HP and costs nothing
Old 04-26-2011, 03:08 PM   #6 (permalink)
Nigel's Avatar
Now I am confused. What system gives you just 1 hp? I was comparing the long vs short version (in other words they are very similar). Both of them will net you 10 hp peak and 15 lower midrange with a PCV and map.
P.S. By fitting either you loose more than 13-14 pounds (i.e 10 hp more (with PC) and 13 lbs less). And if you know the answers, don't ask the questions. Get whatever you want, sheesh!
N.
Old 04-26-2011, 04:32 PM   #7 (permalink)
Sounds like you best stick with the standard system and just put the Akra slip on then!
Old 04-26-2011, 08:18 PM   #8 (permalink)
Banned
N.
I'm not sure why you are confused are you not the one that mentioned "a hp"
That must mean ONE because you mentioned "2 hp".
The difference between 1 and 2 is 1.
I understand about the weight savings and the HP gains that are available with the different systems.
But you are the one who mentioned a 1 hp gain with a longer can.
Is it worth the cost and trouble to change that can baack and forth for 1 or 2 hp?
If I already had all the answers that I am looking for before I purchase a system for my bike I would not be wasting my time on this or any other forum trying to sort out facts from fiction.
Old 04-26-2011, 08:25 PM   #9 (permalink)
Nigel is probably one of the most helpful people on this forum. You yourself obviously know it is loud or you wouldnt be talking about a db killer. His hp difference was only referencing between the long and short can. If you do a little search function action you will notice many people that have the short can talk about how extremely loud it is. If your track usually test exhaust then probably not a good system for you. Maybe look more towards a austin can so that you have the option to quiet the exhaust down, and have a smaller look. Just not a good idea to argue with respected members when you have 10 post.
Old 04-27-2011, 12:40 AM   #10 (permalink)
Lee#144's Avatar
wow 12 posts and already insulting people that are answering your questions? I don't even need to shake my magic 8 ball to for see your future here
#144 CMRA Just a slow novice
