Originally Posted by R35 GTR
What is the best WOT air/fuel I think 13.2 was pretty ideal but seen some even leaner
IMO, that is somewhat of a loaded question. If you're talking about on a dyno, then I'd say from what I've seen and heard, I'd agree - 13.2 to 13.4. That being said, many drag racers and friends I know will tune (on a dyno) for 12.9-ish on a dyno realizing that when they get to the track, they will see slightly leaner (0.3-0.5 leaner) AFRs due to the ram air affect at higher speeds. And get better ETs then if they dyno tuned for 13.2-13.4 to begin with.
So to answer you're question... if you want the best dyno sheet to hang on your wall, then 13.2 to 13.4. If you want the best traps and ETs, it may likely be richer on a dyno (12.9ish) which would allow it to lean out on the street to 13.2-13.4 once you get the affect of ram air.
Some may argue otherwise, but this was one of the reasons I did a 6-gear map with the AutoTuner. Results on a dyno do not always translate 1 to 1 on the track or street. Don't get me wrong, a dyno is a great tool, but should not be treated as the only tool. It'll get you well on your way faster than most other means... but should be followed up with some real world testing too.
That's my $.02....
