Yes... Your PCV came with a CD or you can go online and download the DynoJet (PCV) software from there. Once installed, connect your laptop to the bike and launch the software. It may bring up the map right away (from the PCV). Just to be sure, select (in the lower left corner) "Get Map"... then you will see what ever map is on the PCV. You will also (if they're present) see some description in the lowest part of your window - some information about your map. Best bet at this time would be to click "Save Map"... then save it to your laptop. That way, you have an electronic backup/copy of the custom map they did for you.
