Drive-by-wire to cable? - BMW S1000RR Forums: BMW Sportbike Forum
Graves MotorsportsSportbikeTrackGear
Old 01-06-2013, 06:47 PM   #1 (permalink)
awelch85's Avatar
Default Drive-by-wire to drive-by-cable?
It seems like the only reason for drive-by-wire is to keep the engine's power at bay and make tuning a PITA.
As far as I know there's no such conversion kit, if there is let me know.
To the engineers and fabricators out there, how hard would it be to make a conversion kit to a cable driven throttle? Is it possible?
Old 01-06-2013, 07:15 PM   #2 (permalink)
bsinclair's Avatar
with ecu tuning the throttle bodies can be programmed to open sooner. they can also reprogram the torque managment of this as well as restore timing in the lower gears. give max bmw a shout as they have been doing ecu editing on bmw's for quite some time..with the hp tuning software this can be done but at a cost of $5000. im sure they will do it for $300-500 to restore that feeling your missing...
bsinclair is offline   Reply With Quote
Old 01-06-2013, 10:34 PM   #3 (permalink)
Electronic throttle control is an integral part of bike and completely "baked in". Sort of re-engineering the entire fuel delivery system and fitting an aftermarket ECU, there is no way to replace it with a direct system.
You can address most any fueling issues pretty easily in the aftermarket, so I'm not sure why you think the root cause of any tuning issue is the electronic throttles.
Old 01-07-2013, 07:20 AM   #4 (permalink)
awelch85's Avatar
I was just thinking that if we weren't limited to the x% of throttle that we are we'd be able to tap in to more power.
Old 01-07-2013, 10:37 AM   #5 (permalink)
You won't really get more power (overall), just more power sooner (in the bottom three gears I believe?!).
A lot of stuff going on w/the ride by wire though... so doing away with it probably isn't the best option for the S1.
__________________________
Old 01-07-2013, 12:16 PM   #6 (permalink)
I thought there were some ECU updates that eliminated the lower gear power restrictions, but I'm not sure. In any event, virtually no rider can actually use 180-RWHP in 1st gear - you either get wheelspin or a wheelie.
Old 01-07-2013, 12:32 PM   #7 (permalink)
I believe you're correct...
Old 01-07-2013, 05:04 PM   #8 (permalink)
bsinclair's Avatar
the factory still has the first 3 gears limited regardless of years and updates. the dbw on the newer bikes is more refined but not perfect. max's bmw has been flash tuning for quite some time and can fix alot of what your feeling and improve other things.
Old 01-08-2013, 03:58 PM   #9 (permalink)
Yes, when I said "ECU updates" I meant aftermarket. Still think that for all but the top 2% or so of riders at the track, the lower-gear power restrictions are probably a good thing.
Old 01-08-2013, 06:54 PM   #10 (permalink)
awelch85's Avatar
...the lower-gear power restrictions are probably a good thing.
Probably, but I still think it'd be fun to have, just to feel it. Most of the dbw being tied in to the system would be with ABS and traction. Assuming a bike didn't have those I wonder what difference the bike would have at WOT off the line.
