Question about PCV when hook to computer engine running - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-25-2012, 03:59 PM   #1 (permalink)
pekespeed's Avatar
Default Question about PCV when hooked to computer engine running
I just installed my AR full system and PCV I noticed when I open a map on my computer it saids Gear 6th when I plug into my bike running at idle it shows Gear 1. I do not have the blue/white wire for gear sensor hooked up
my map is from austin racing a single 6th gear map. Is this normal ?
pekespeed is offline   Reply With Quote
Old 11-25-2012, 05:51 PM   #2 (permalink)
Don't know the default when they make a map, but I've got the white/blue wire hooked up and it shows the correct gear when I hook up to the computer. But the map may just be the same for every gear.
Old 11-26-2012, 11:45 AM   #3 (permalink)
pekespeed's Avatar
Ok, so I hooked up (GPS) blue/white wire to middle purple wire today well I'm sure it is installed correctly I notice now when hooked up to the the computer bike running it shows opposite of gear it is in example
1 on bike shows 6 on my computer
2 on bike shows 5 on my computer
on down to actually in 6th gear computer screen shows 6
I thought I read where a forum member had same issue when he dynoed his bike. I'm running a single 6th gear map (I think) Rich from AR installed it.
The PCV I purchased when I bought exhaust from AR. The PCV is from UK but I'm pretty sure USA and UK PCV's are the same
