Removing exhaust valve's servo's/motor's info - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-01-2012, 04:18 AM   #1 (permalink)
BUZZ's Avatar
Default Removing exhaust valve's servo's/motor's info
Some one enlighten me,im running a full exhaust system and disconnected all the cables that used to be connected to the stock exhaust,so my question is can the exhaust valve servo's be removed and disconnected and will the bike show up any fault codes on dash or is there something in the hp parts list that corrects any fault codes once disconnected.???????? Cheers
2011 motor sport s1krr,puig dark screen,watson flush turn signals,hp levers,hp rearsets,pcv,k&n race filter with custom map,austin racing gp2 inconel and titanium exhaust system,sharkskinz belly pan and stock panels custom painted,r&g crash protection,gb racing engine covers,factory pro detent spring,symmetrical smoked headlight covers,pro suspension set up and one crazy rider..!!!!
Old 11-01-2012, 06:05 AM   #2 (permalink)
Jax0238's Avatar
I'm pretty sure it does throw a code but is considered a soft code as it does not show up on the dash but can be read by the dealer when hooked up for diagnosis. Could be wrong but I disconnected my rear servo and never showed a code on the dash but dealer said there was a code showing up in diag.
Sent from my iPad using MO Free
Jax0238 is offline   Reply With Quote
Old 11-01-2012, 07:07 AM   #3 (permalink)
I saw a post somewhere that even with the servo motors removed the ECU showed the same fault code as the cables disconnected. You could try unplugging them as a first step, then if there's no issues go ahead and remove them. I kinda like that clack clack noise when I turn on the key, so I left mine on.
Old 11-01-2012, 09:43 AM   #4 (permalink)
yangins's Avatar
I have all my servo remove no light at all. Does through internal codes but no effect on how the bike runs.
Mad Yellow Bumble Bee
Previous bikes
1966 CB160 CAFE
01 Ducati S4
02 Aprilia RSV R
yangins is online now   Reply With Quote
Old 11-09-2012, 08:00 PM   #5 (permalink)
DannyD's Avatar
Installing a full exhaust as I type this servos and cables removed no "real"issue? Just clarifying???
DannyD is offline   Reply With Quote
Old 11-09-2012, 08:47 PM   #6 (permalink)
That's right, only your dealer will know for sure.
