S1000RR - My journey flash tuning the stock DME - Page 7 - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-22-2012, 07:59 AM   #61 (permalink)
d40
Originally Posted by bren RR View Post
Pretty much done, found all limiters - switching over to working over OBD2 and getting the handhelds working and programming. All bench work done. Final revision (OBD2) will be completed on the dyno when the cables show up.
ETA JAN 1 for completed project.
Curious to know if you thought about creating an enhanced stock map as well? Maybe one suited to the Akra slip on...
d40 is offline   Reply With Quote
Old 11-24-2012, 06:19 PM   #62 (permalink)
We have a bunch of different maps created: stock enhanced, slip on, catless, full header etc, race fuel. Far superior to stock race ecu or HP4 engine mapping.
bren RR is offline   Reply With Quote
Old 11-24-2012, 07:01 PM   #63 (permalink)
So when are you planning on releasing this?
EB233HWT is offline   Reply With Quote
Old 11-24-2012, 08:54 PM   #64 (permalink)
d40
That's great news. Can't wait to see the numbers...
There were differences in the number of throttle, power and torque curves between the first and second iterations of the ECU, i.e. throttle curves went from four to two and both performance and torque curves went from two to three.
1. Did you have to do two different tunes that lay over the existing architecture relative to each iteration, OR
2. Are you able to simply adjust the total number and kind of curves to go either way, i.e. for a 10/11 could you retain four throttle curves but add the one additional power/torque curve like the 12/13/HP4 or even add two more to create four truly unique modes, or would someone with 12/13/HP4 for instance be forced to get added throttle curves like 10/11 and lose their additional power/torque curve since a 10/11 ECU was your base?
I ask because I was going back and forth between getting an HP4 or keeping my 10 and getting the Race ECU, but now the possibility of my baby w/ a "far superior" flash, or even better, an HP4 with one changes the equation. At the very least I might have to get a 12/13 with one. Damn..lol
Old 11-24-2012, 10:51 PM   #65 (permalink)
Rush66crp's Avatar
Is it ok to say I'm skeptical until I see some graphs/numbers or anything?
I appreciate the hard work regardless.
Rush66crp is online now   Reply With Quote
Old 11-24-2012, 11:25 PM   #66 (permalink)
1hotlimo's Avatar
Very cool info. Where are you located?
2011 S1000rr
CVMA #65
jr3racing.com
1hotlimo is online now   Reply With Quote
Old 11-26-2012, 05:09 PM   #67 (permalink)
2. Are you able to simply adjust the total number and kind of curves to go either way, i.e. for a 10/11 could you retain four throttle curves while adding one additional power/torque curve (like the 12/13/HP4) or even two more to create four truly unique modes, or would someone with 12/13/HP4 for instance get an added throttle curve and lose their additional power/torque curve since a 10/11 ECU was your base?
We can offer both throttle curves - all maps are identified and mappable. We will have 2 options or so (4 curves or 2 curves).
Custom throttle mapping per bike will be time consuming however.
More info will be released when we decide to sell these and sponsor of course. You can decide if it's for you or not. The HP4 download we've tested has very very minor fuel changes (for exhaust changes) and has an otherwise stock base S1000RR map for performance. Everything else is based on abs/dtc/rear suspension electronics that is not included in the data area of a normal performance tune which will require other components more then a flash.
Final testing is right in order - handhelds are here and we're testing flashes without ecu removal now. Upload/download through the tail of your bike with multiple maps!
Old 11-26-2012, 06:32 PM   #68 (permalink)
varunrajg's Avatar
Very cool!!!
varunrajg is offline   Reply With Quote
Old 11-26-2012, 06:57 PM   #69 (permalink)
This will be the sh!t.
M GmbH is offline   Reply With Quote
Old 11-26-2012, 11:19 PM   #70 (permalink)
Do you already have any graphs of dyno or other realized tests?
Here in my country there are some Japanese motorbikes with the ECU reflashed. Watch this 2012 ZX10 of a friend of mine.
2012 ZX10R Top Speed Run 336km (Click HD quality to see better) - YouTube
plumero is offline   Reply With Quote
