Auto tune install time - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-26-2012, 12:40 AM   #1 (permalink)
Islingpaint151's Avatar
Default Auto tune install time
Hey guys I just had a Pcv installed on my 11 s1000rr and it took 5hours at the shop. Is that normal? I also just bought the auto tune kit so how long should I expect install to be? Thanks
Islingpaint151 is offline   Reply With Quote
Old 09-26-2012, 01:18 AM   #2 (permalink)
kismetcapitan's Avatar
five billable labor hours?? To put things in perspective, when my bike died on Sunday, to test if it were the PCV, we pulled it from the bike. On the side of the road using only tools from the toolkit, and it sure as hell did not take five hours! Probably 20-30min to pull it and reinstall it, but there's a faster way that doesn't require taking apart half the bike, if you have a helper to hold the fuel tank. It took me five hours the first time I installed one, but I had never done it before.
the steps:
- remove seat
- undo side tank covers (all three pieces can come off as one if you undo the nine screws that actually hold the tank fairing pieces to the bike)
- undo bolts that hold the tank to the frame
- take out 10mm wrench and remove the bolt that holds the rear of the tank
- have friend hold the tank up
- snap the injector harness into place (2 minutes)
- tap wire into the throttle position sensor wire
- screw in ground wire to the battery
- reassemble
that ain't five hours!!
To do the Autotune:
- remove lower fairing if needed to get to the wideband sensor bung.
- Screw in wideband sensor
- route wiring up through the bike to the Autotune module
- connect Autotune with the PCV module
- wire in the Autotune with a switched 12V positive and negative wire (I used the wire that used to light up my license plate)
- make sure the Autotune is connected correctly and the terminal plugs are where the instructions say they should go
- button everything up.
IIRC I only had to remove the bellypan, seat, and pillion seat. You'll need a handful of zipties.
2000 Ducati ST4 Desmodromico
2010 S1000RR (sold)
2007 F800S (sold)
Old 09-26-2012, 09:01 AM   #3 (permalink)
indixon's Avatar
I put mine in last week, took me 1.5 hours from start to finish, and this was the first time I had put one in! 5hrs, they are ripping you a new one!
_______________________
2012 Red and Alpine White Carbon package S1Krr
indixon is offline   Reply With Quote
Old 09-29-2012, 09:29 PM   #4 (permalink)
Damn I knew it well they will not be getting me again for the autotune install. Thanks guys
Sent from my iPhone using MO Free
Old 09-29-2012, 10:25 PM   #5 (permalink)
it only took my bmw master tech 1/2 hours. He charge me $35 for installing pc5
802452 is online now   Reply With Quote
Old 10-01-2012, 03:00 PM   #6 (permalink)
shashankmittal's Avatar
Autotune install should not take more than 1hr, assuming you have the right tools in place and you are handy working on your bike.
That is a very good price, I would assume anywhere from 1-1.5hrs is reasonable for a dealer.
2013 BMW F800GS
2010 S1000RR (track only) (street parts available for sale)
2004 Royal Enfield 500 Electra
1997 Yamaha RX135
1990 Yamaha RD350
Old 12-01-2012, 10:11 AM   #7 (permalink)
pekespeed's Avatar
Default Suggestions Welcomed
Where did you run your O2 sensor cable up to AT?
I got mine through rear shock area of swingarm but I'm scared it might get caught on something.
pekespeed is offline   Reply With Quote
Old 12-01-2012, 10:30 AM   #8 (permalink)
Don't attach/put it where there are moving parts (ie. swingarm, shock, etc.). Try and route it to the frame and then up.
__________________________
