hi, so, i'm interested in AR too and wondering what exact configuration is yours? ARCs what? do you order direct from UK or some mediator in US? how much is the pc5 with the AR's map ?
and if you take the 'dB killer' out, you can do full throttle extended time w/o the CF can breaking down, right ?
james R
2012 stock srr, triColor
Sent you a PM
_______________________
2012 Red and Alpine White Carbon package S1Krr
The only thing that will cause the carbon to deteriorate is prolonged use with a db killer at full throttle. This is due to excessive heat build up in such a small end can such as the GP Ultimate . If you want the lower db levels it is advisable to go for the V2 or V3 silencers as they have a larger area and can cope with a db killer inserted at full power. Adding to that, Titanium is the best option.
