Akrapovic Shorty PCV Map - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-06-2012, 09:43 PM   #1 (permalink)
charlie335's Avatar
Default Akrapovic Shorty PCV Map
Hey guys,
Do any of you have a map that seems to work well with the Akra stainless full system w/ short can? I just installed my PCV and the base map i loaded isn't very good. Low to mid range is very lacking, and running way too lean. The shorty stainless full system is the only mod I have on the bike, and my elevation is near sea level (Vancouver, Canada).
Thanks in advance!
2011 S1000RR / Akrapovic / Attack Performance / Lightech / Dunlop
charlie335 is offline   Reply With Quote
Old 05-11-2012, 03:16 AM   #2 (permalink)
Cyb3rSt4Lk3r's Avatar
I've got a single map and a 6-gear map. I'm at around 900 feet, so close enough. if you have a new pcv with the blue wire, you should hook up your gear position sensor and run the 6-gear map, it's much smoother in every gear than the single map. PM me your email and i'll send them both to you. I have an auto tune (which i highly recommend, especially with Vancouvers elevation differences), so the maps have AFR tables too. The 6 gear one is based on 1000RR's AFR tables that he was kind enough to share. If your pcv doesn't have the blue wire you can still use the speed sensor to calibrate for a 6-gear map too.
Cyb3rSt4Lk3r is offline   Reply With Quote
Old 05-11-2012, 08:23 AM   #3 (permalink)
Rated-RR's Avatar
Just out of curiosity what afr values are you running?
Sent from my SGH-T989 using Motorcycle.com Free App
Rated-RR is online now   Reply With Quote
Old 05-12-2012, 02:04 AM   #4 (permalink)
The target AFR is different depending on the gear, throttle position, and rpm. The tables that i use were originally posted by 1000RR.
