I had my ARCS exhaust without the Bazzaz ZFi and ZAFM and performance airfilter for nearly 1 month, no issue at all, but i had a lot of back fires
I suggest you install Driven block plates which should reduce the backfires to 99% and to give you more accurate reading of the AFR.
The difference after you install Bazzaz or PC5 and airfilter with your ARCS plus the help of a proper dyno tune is great
you'll really like it
