Originally Posted by markjenn
Frank, it would be good if you could explain exactly what your "kit" does and where it is on your web site.
As most of you know the stock axle nut/spacer protrudes through the fork leg about an inch, the protruding spacer makes it aggravating to get the wheel out and in even with the calipers off.
By making the sleeve nut flush with the fork leg and putting the spacer in the wheel, the wheel comes in and out much easier and opens up the door for the option to change the wheel without removing the brake calipers.
To change the wheel without removing the calipers you must bevel the edge of the brake pads (pic attached) and either remove or modify the front fender (pics attached) Once modified the fender will flex enough to get the wheel out and in with the calipers attached.
As another option I also make a pull cone for the front axle which is tig welded on, so you have something to grab and pull the axle out with.
From my website, click the "Online store" tab then click S1000rr parts to see all the s1000 stuff i have.
FF
