Removing ABS - Page 3 - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-07-2010, 12:22 PM   #21 (permalink)
Originally Posted by Steverin06 View Post
No, what's funny is that idiots like you try to make a point when the fact is that what I type is actually legible, so that the people in this thread can reply and talk about the S1K..
Oh dear, you had to make it personal.......again......Never mind. Hope you manage to sort your problems.
Old 09-07-2010, 01:29 PM   #22 (permalink)
Originally Posted by russianvr4 View Post
it REALLY ******* irks me when im trying to find an answer and someone starts lecturing me on why its not good to do what im trying to...
my parents always told me: if you have nothing good to say, dont say it at all.
.... then follow your own advice.
Old 09-07-2010, 01:33 PM   #23 (permalink)
Aww, do I need to call a whambulance? Maybe you should stay out of the kitchen.
I don't get that post. He was actually trying to help.
Steverin06 is offline   Reply With Quote
Old 09-07-2010, 01:42 PM   #24 (permalink)
You don't get the irony of someone posting a negative post about how it is bad to post a negative post?
The "if you don't have something positive or constructive to say then shut up" is a fine rule, but the sword cuts both ways.
Old 09-07-2010, 03:55 PM   #25 (permalink)
Absolutely true, but generally its the first pointless wave of the sword that opens the wound......
Old 09-07-2010, 04:31 PM   #26 (permalink)
i dont have a single negative post in this thread, i was actually trying to help, please reread my posts and eat your words.
that was negative ^^
Old 09-08-2010, 01:24 AM   #27 (permalink)
FWIW, I made aluminum spacers to replace the banjo fittings on the ABS pump, sandwiched them between two copper crush washers and installed the stock banjo bolts. Next, I made new -3 brake lines and installed the 19RCS master cylinder. No more ABS, TC still intact, Woodcraft front stand now usable.
I tried to build a set of lines that used a single line to the master that tee'd into two lines for the front calipers, but I just couldn't get them to work. This bike is packaged very tightly indeed, especially when the forks are compressed. I ended up using a dual line setup with a double-length banjo in the master cylinder, with the lines routed inside the fork legs. Nothing else provided sufficient clearance or allowed the lines to move freely when the forks compress.
tcchin is offline   Reply With Quote
