Still got bad vibrations through the bars on my S1... - BMW S1000RR Forums: BMW Sportbike Forum
Old 06-05-2010, 04:13 PM   #1 (permalink)
Default Still got bad vibrations through the bars on my S1...
I've had my bike a month today. Got 1400 miles on it, and still having really bad trouble with vibrations through the grips and the right hand side foot peg....
So far I've changed the bar ends to R&G Racing, and added extra weight to these, and also using Renthal grips as I find these softer than the BM ones....but I'm still suffering far too much vibration. Was out for a ride today, and swapped bikes with a friend. He tried my S1, and agreed its bad!!!!
I've had the bike back to the supplying dealer, and they haven't found anything wrong with it
As it stands, I'm struggling to ride anymore than 20-30 miles before my hands are numb. Seen the 10 page thread with various suggestions, but nothing seems to be curing it. Only thing I've thought of today is I have R&G Aero crash protectors fitted, torque'd up to R&G specs. My train of thought is if these are'nt tight enough, would this cause excess vibration of the frame / engine, thus transferring via the frame to the bars?
I'm running out of options, other than selling and getting another Fireblade
I've emailed BMW UK, but still waiting a response. Has anyone else found any other fixes for this? Is it worth tightening up the R&G crash protectors?
Any help would be appreciated!!
Simon B is offline   Reply With Quote
Old 06-05-2010, 04:17 PM   #2 (permalink)
Marky 70's Avatar
Send a message via ICQ to Marky 70
Default Problem-Sloution
You have discovered the problem.The R&G spec of 40 nm is 16 nm less than what the offical BMW manual states these bolts should be torqued to 56 nm.This lower torque is causing excess vibration through the whole bike. How many people on here complain that they can only ride for 30 miles, common sense.Tirquethem to 56 nm -done.
Marky 70 is offline   Reply With Quote
Old 06-05-2010, 04:26 PM   #3 (permalink)
AMPforE's Avatar
Sorry to hear your having so much trouble. Bad vibration is difficult to overlook. Couple things, what octane gas are you running? Is the vibration the same throughout the RRM or does it smooth out at 5k and above?
The vibs bother me also, I have a pair of Driven superbike grips to go on and I also have heavy throttlemeisters on the way. Driven Grippy grips and motivation barends helped me with my CBR1000. I don't think the R&G's are as heavy as the TM's or Motivation barends. It also took about 4000 miles before the CBR smoothed out so you may just have to endure a little longer. Some say it gets better with miles and some say it's the same.
If the Driven grips and TM's does not do it for me I'm going to change the gearing to keep me out of the 4K range which is where the vibration is the worst for me. The gearing is pretty tall anyway so a -1/+2 will do wonders.
1991 Suzuki Bandit 400
1996 Kawasaki ZX6
2006 Triumph Speed Triple
2009 Honda CBR1000RR ABS
2010 BMW S1000RR
ABS-DTC-Shift Assist
Fastest Color Motorsport
Old 06-05-2010, 04:27 PM   #4 (permalink)
AMRRA12's Avatar
if that does not fix it try buying a can of spray foam and fill the inside of the bars!
AMRRA Open SS Expert #1
Sponsors:
Lithia Motors
Snap-on tools
Big Bobs Flooring
Mat-Su Tattoo
AMRRA12 is offline   Reply With Quote
Old 06-05-2010, 04:36 PM   #5 (permalink)
Depths_of_Mind's Avatar
I've also heard BB's or lead sinkers will work too... not sure how well they will actuall work, but heard they do.
Old 06-05-2010, 06:14 PM   #6 (permalink)
Cheers guys for the help so far. I'll tighten the crash protectors up to 56nm tomorrow, and will probably add a bit more weight to the bar ends and will see how it rides then
The vibes start around 3k, then get a lot worse from 4-7k....
Old 06-05-2010, 06:30 PM   #7 (permalink)
The ThrottleMeisters did zero for me on vibes. No that much difference in weight off the stockers (they are the H-D ones too.).
Some Olympia 760 Air Force gel-palmed gloves helped maybe 20%.
I have a pair of NOJ Neoprene Grip Covers that also seem to help, maybe 20% as well. Haven't tried the "Grip Puppies" yet. A (fugly) CrampBuster helps too as I can get my hand off the grip and use my palm for a bit.
Seriously, someone needs to come up with an "Isolation kit" for the bars.
I don't have an issue with the foot pegs at all, but I wear some BMW Air-Max (?) boots with some gel inserts so that may be why. I don't let my heel touch that vibrating heel-plate either (some isolation rubber needed there too?).
Mack
Old 06-05-2010, 08:27 PM   #8 (permalink)
AMPforE's Avatar
That is odd, I am smooth at 3k, and the worst of it is at 4k, and then smoother at 5k and above.
Mack
TM's seem to be the savior or no help at all. According to them they are much heavier than stock.
1996 Kawasaki ZX6
2010 BMW S1000RR
Old 06-05-2010, 10:56 PM   #9 (permalink)
I don't know, but my stockers were steel and they didn't seem that much different than the TM H-D ones, not enough to matter. If I had a scale I'd weigh them.
Actually I 'd give them a 20% improvement - if that - over the stockers. I think the dampening claimed off the TM's is more hype. After 30 miles, I still get the damn "Where's that front brake lever at?" sensation. I've got some of the NOJ's around and I need to try them out on both grips. They're a simple Velcro-on type of foam/neoprene stuff.
I'm still wondering about the sub-out for the BMW grips off the touring bikes. If the 'NOJ Grip Wraps' or the 'Grip Puppies' cannot do any better, then I doubt the change-out to the BMW touring grips would do any better.
I still think the bars themselves need some sort of isolation.
Mack
Old 06-06-2010, 01:44 AM   #10 (permalink)
mine was terrible at 4k just at 4k , after 600 service , vibe is gone, just start tightening **** up, somethings loose
That Nice Guy Beck! is offline   Reply With Quote
Search Engine Optimization by vBSEO 3.3.2
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
