Still got bad vibrations through the bars on my S1... - Page 16 - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-16-2010, 07:50 PM   #151 (permalink)
Originally Posted by SPETSNAZ View Post
Hmm.got a link....?
THx
Here ya go: GRIP PUPPIES ™ Small. (1 Pair) Pick First Class Mail for Free Shipping. - Motorcycle Parts and Accessories for the Sport Touring Enthusiast at Motorcycle Accessories from California Sport Touring, Inc.
2010 - Audi S4
2010 - S1000RR
HyperM3 is online now   Reply With Quote
Old 11-17-2010, 06:13 AM   #152 (permalink)
Originally Posted by Mack View Post
On that buzzy foot plate, someone here mentioned doing some mods to theirs by using some rubber grommets or something along those lines. I've often thought maybe a large fender washer or doubling up on that plate with one behind it to stiffen it up a bit too. The lower part near the mounting bolt doesn't buzz as much as the upper part so it may be too thin for the task at hand.
Mack
That was me, my 'fix' for the RH footrest is:
If you look at the mounting there is a large washer on the outside of the mount and the exhaust on the other side, these 'squash' the rubber mount
If you take the mounting bolt out there is a steel spacer through the middle of the rubber, just add a thin washer the same inside and outside diameter as the spacer and fit it next to the spacer, this lessens the tension on the rubber mount from the exhaust and large washer on the outside of the mount and reduces the vibes considerably. Dead easy and cheap
mikef4uk is offline   Reply With Quote
Old 11-22-2010, 01:31 PM   #153 (permalink)
ok ----ALL footpeg and heel plate vibrations cured Now to give the bars some attention without fitting any tampon shaped bar ends .........mmmmmmmmhhhhhh
nickg1977 is offline   Reply With Quote
Old 11-22-2010, 02:32 PM   #154 (permalink)
I should go and do Mike's spacer upgrade sometime this winter. Not a big issue for me, but one that may help overall.
I've yet to hear what Don at Vibranator came up with when he posted here about using their product on the S1000RR handlebars and were working diligently on it.
Maybe he gave up?
Mack
Old 11-23-2010, 04:13 AM   #155 (permalink)
Somehow i dont get the footpeg -washer trick.
Can someone please explain again where exactly he placed that extra washer?
What i did:
I unboltet the exhaust from the footpeg. The set-up would be: bolt, then a conical big washer, then the thick rubber gasket, then the exhaust hanger, big washer, and then the nut (i've got the akra short pipe installed).
Now, i placed a small M8 washer between the rubber gasekt and the exhaust hanger in the back .. that leaves about a 1mm space between rubber gasket of the footpeg an the exhaust hanger bracket. Unfortunately, the vibrations stayed the same.
Anything i'm missing here?
I placed the washer where the red arrow points to, behind the footrest.
python4933 is offline   Reply With Quote
Old 11-23-2010, 07:38 AM   #156 (permalink)
What i did:
No thats it, it worked fine on mine, you could also try loosening the clamp between the silencer and cat housing whilst the exhaust is hot in case there is any tension on the rubber mount from there
Old 11-25-2010, 06:16 PM   #157 (permalink)
jswcat's Avatar
I went with supporting my upper body with inner core and holding "lightly" with the paws and it made a HUGE difference. Added some Throttlemeisters more for the cruise setting but they seemed to help out to a small degree.
jswcat is offline   Reply With Quote
Old 12-03-2010, 12:42 AM   #158 (permalink)
My .$02, I have 2964 miles on my street driven only bike.
I do have an Akra Slipon.
I have stock grips.
I ride agressively.
I have NEVER noticed any vibration that has ever put me off.
Their is something wrong w, your bikes if they vibrate so much that you have to go to such great lenghts to squelch it.
I guess I was 1 of the lucky 1s and got a good S 1000 RR.
I also clean and lube my chain every 500 miles and clean my bike every time I ride it.
Rarebird is offline   Reply With Quote
Old 12-03-2010, 08:58 PM   #159 (permalink)
Originally Posted by Simon B View Post
I've had my bike a month today. Got 1400 miles on it, and still having really bad trouble with vibrations through the grips and the right hand side foot peg....
So far I've changed the bar ends to R&G Racing, and added extra weight to these, and also using Renthal grips as I find these softer than the BM ones....but I'm still suffering far too much vibration. Was out for a ride today, and swapped bikes with a friend. He tried my S1, and agreed its bad!!!!
I've had the bike back to the supplying dealer, and they haven't found anything wrong with it
As it stands, I'm struggling to ride anymore than 20-30 miles before my hands are numb. Seen the 10 page thread with various suggestions, but nothing seems to be curing it. Only thing I've thought of today is I have R&G Aero crash protectors fitted, torque'd up to R&G specs. My train of thought is if these are'nt tight enough, would this cause excess vibration of the frame / engine, thus transferring via the frame to the bars?
I'm running out of options, other than selling and getting another Fireblade
I've emailed BMW UK, but still waiting a response. Has anyone else found any other fixes for this? Is it worth tightening up the R&G crash protectors?
Any help would be appreciated!!
Bent crank can cause this vibration. Seen it done on CBR's that has been abused
jkim is offline   Reply With Quote
