HELP. Something Stuck in Stem Hole Thing! - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
post #1 of 17 (permalink) Old 06-18-2017, 04:51 PM Thread Starter
SaiyanMuscle's Avatar
EDIT: SOLVED! I put a steel wire through the small rubber hole, then tied the bottom wire around a small hook screw: http://www.homedepot.com/catalog/pro...537b6_1000.jpg
Then I got a cue tip that I dipped in olive oil & lubricated the inside of the HOLE. Afterwards, I got the top wire, which I will be pulling, & wrapped it around a steel rod which I was gonna use to pull the rubber thing up. It took a good 2 minutes but it popped out!!
THANKS TO EVERYONE FOR THEIR SUGGESTIONS, IT WAS GROUP EFFORT! & LIKE ALWAYS, THIS FORUM HAS HELPED ME TIME & TIME AGAIN thank you so much!!
I was installing my ram mount. I've done it before successfully but this time, the world is sending me a message that I shouldn't ever touch anything on this bike because each time I do, something goes wrong.
I pushed in the ram mount rubber thing into the stem hole thing(I have no clue what that's called) and I was tightening it and I thought it wasn't tight enough so I was going to make some adjustments but I accidentally loosened it too much that it came apart inside the hole the rubber thing is stuck inside the hole. I'm terrified because I don't even know what that hole is supposed to do.
Long story short:
There's a rubber thing stuck in the hole. I pushed it down a little further out of anger with a steel rod thingy. What should I do? Should I push it down further but will it come out the other end? ..is that even possible? PLEASE HELP WHAT DO I DO?
Image attached below of THE HOLE.
2016 BMW S1000RR
2014 Yamaha R6
Last edited by SaiyanMuscle; 06-18-2017 at 07:38 PM. Reason: Adding the solution to my posted problem.
SaiyanMuscle is online now
post #2 of 17 (permalink) Old 06-18-2017, 05:49 PM
You need a steel hook thingie, get in there and excise the demon. Or super long needle nose pliers.
skapan is offline
post #3 of 17 (permalink) Old 06-18-2017, 05:52 PM
SkyDan's Avatar
If rubber piece has a hole, use a hook made from wire hanger for instance to pull it out.
Sent from my EDI-AL10 using Tapatalk
SkyDan is offline
post #4 of 17 (permalink) Old 06-18-2017, 05:53 PM Thread Starter
There's no room in there to use pliers or even a steel hook thing
Could pushing it down all the way work instead? There was a nut below the rubber piece that just fell through onto the ground. I wanted to ask before doing anything further.
2016 BMW S1000RR
2014 Yamaha R6
post #5 of 17 (permalink) Old 06-18-2017, 05:55 PM
Maybe. Never had problems with my stem hole.
skapan is offline
post #6 of 17 (permalink) Old 06-18-2017, 05:58 PM
SkyDan's Avatar
You will need to move the brake line to free the hole on the bottom to push the rubber down and out.
SkyDan is offline
post #7 of 17 (permalink) Old 06-18-2017, 06:03 PM Thread Starter
That black rubber thing is what's stuck in the hole.
Sorry for asking more questions but where's the brake line & how do I move it?
2016 BMW S1000RR
2014 Yamaha R6
post #8 of 17 (permalink) Old 06-18-2017, 06:06 PM
SkyDan's Avatar
You should be able to hook that. If not the brake line is right below the hole on the bottom of the stem. Remove front fender, you will see a plastic cover, remove it. Next, move the brake line T connector. That will expose the stem hole.
SkyDan is offline
post #9 of 17 (permalink) Old 06-18-2017, 06:07 PM
z00
You can push it down through the other end. But you need to look under the triple, there is a trim piece you might need to remove to let rubber piece freely fall. I had to do this when I used a triple front stand.
2015 s1000RR
>10K club president.
If you ain't slidin', you ain't ridin'
z00 is online now
post #10 of 17 (permalink) Old 06-18-2017, 06:20 PM Thread Starter
So I pushed a small wire through to see where it exactly comes out through, I can see that there is something that kind of restricts it to fall through like you said. I guess there's no other way but to push it through.
Just a thought, since it's a small rubber piece....if left there, would it be a bad thing?
2016 BMW S1000RR
2014 Yamaha R6
Human Verification
