Playing around with camera mount points - BMW S1000RR Forums: BMW Sportbike Forum
post #1 of 12 (permalink) Old 01-07-2017, 02:35 PM Thread Starter
eagle734's Avatar
Curious what others are doing for mount points on the swing arm and subframe. Here are my observations exploring with a "knee puck" and "tire" POV angles.
Spool M8 bolt mount
Upside: awesome angle, as low as you can get, great sound capture next to exhaust (rhs), works both front and rear.
Downside: limited shock absorption, shaky video; the RAM ball mount has the most pivot flexibility but sticks out too far and may drag at max lean, Gopro mount is more compact and won't drag; can't use spools for rear stand unless you want extra step of adding/removing them each time.
Subframe M8 bolt mount
Upside: good shock absorption, nice med-level angle, close to exhaust (rhs) for good sound capture.
Downside: rear facing only, may interfere with body position.
You can also just stick the camera on tail and nose fairings with 3m adhesive but why be like everyone else
Name:	20170105_170511_resized (Copy).jpg
ID:	162273   Click image for larger version
Name:	20170105_170744_resized (Copy).jpg
ID:	162281   Click image for larger version
Name:	20170105_171815_resized (Copy).jpg
ID:	162289   Click image for larger version
Name:	20170105_171939_resized (Copy).jpg
ID:	162297   Click image for larger version
Name:	20170105_172927_resized (Copy).jpg
eagle734 is online now
post #2 of 12 (permalink) Old 01-07-2017, 06:21 PM
jstilt's Avatar
Check the chain guard bolt on the back of the swing Arm. I was playing around with that location myself.
The swing Arm spool sets the camera to far out for my liking.
I like the subframe mount, but need to make a bracket for it to mount underneath.
jstilt is offline
post #3 of 12 (permalink) Old 01-07-2017, 07:44 PM Thread Starter
eagle734's Avatar
I played with the chainguard location and like it, my only concern is it's dangerously close to the sprocket should the mount fail (and mounts do fail). Even with safety wire to the axle nut it could be catastrophic. On the RHS it may dangle or get run over by tire--still a risk, no telling what happens when some object hits your wheel at 100mph+.
post #4 of 12 (permalink) Old 01-07-2017, 08:10 PM
jstilt's Avatar
Yeah, no matter where you, or any other rider, mount a camera there is always that risk of it coming off and messing you up or someone else. Can you imagine taking a bouncing go pro to the face at 100+.....ouch!
I think I'm also going to try a reverse helmet mount. Maybe have a little less turbulence if it's mounted on the back of the helmet.
jstilt is offline
post #5 of 12 (permalink) Old 01-07-2017, 08:53 PM Thread Starter
eagle734's Avatar
that would be a cool angle, i don't think i've seen a reverse helmet mount
post #6 of 12 (permalink) Old 01-07-2017, 11:49 PM
You'd get a lot of sky shots I would think. Looking at your avatar and imagining the camera view brought me to that.
'15 S1000RR Black Storm Metallic
Dieci83 Radiator/Oil Cooler Guards, Lamin-X Headlight Film, Lightech Chain Adjusters, MotoDynamics Flush Mounts, NRC Fender Eliminator, Puig DB Windscreen, R&G Tail Sliders, TankSlapper Paint Protection Kit, TechSpec Tank Grips, Woodcraft Case Covers, Woodcraft Frame Sliders, Woodcraft Axle Sliders, Woodcraft Swingarm Spools, Yoshimura R55-LE Slipon
smiller4169 is offline
post #7 of 12 (permalink) Old 01-08-2017, 03:08 PM Thread Starter
eagle734's Avatar
Not if you mount it on the side of your helmet..
post #8 of 12 (permalink) Old 01-10-2017, 01:51 PM
jermc is offline
post #9 of 12 (permalink) Old 01-10-2017, 03:00 PM
Here is what I have done.
My front mount:
My rear mount:
Mr rear mount is on the swingarm. It hasn't fallen for me and the tests so far are good. I will do a real test soon with high speeds and more lean angles. I can try and look for a pic if you guys are interested.
SysKnight is offline
post #10 of 12 (permalink) Old 01-11-2017, 10:12 PM
Flalex's Avatar
I see alot of guys mount it on the tank . thing is i have a black windscreen so not for me
MTL - 2015 S1K
Flalex is online now
Human Verification
