Happy veterans day! Good day to get this project done.
I wanted to install a fuse box to power a GPS, a USB cable for the tail bag, and have room to add more items such as my V1.
the before:
After:
Per many requests, this is the wiring diagram for the fuse box.
what you need is:
Fuse box (the diagram says Blue Sea. but that was for my VFR. The blue sea is too big for the space under the seat)
A 30Amp relay
get 2 spools of 25ft of wire
red is positive
black is negative
switched power = tap into the tail light. That way, the fuse box will only have power when you turn the key.
Hope this helps!
Garmin Power cable from fuse box to GPS unit:
The cycle guys tail bag now with power:
And now with winter coming... Battery tender terminal ready:
the before:
After:
what you need is:
A 30Amp relay
red is positive
black is negative
Hope this helps!
