Can someone confirm? - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-09-2012, 11:35 PM   #1 (permalink)
Default Can someone confirm?
I've read numerous threads about our bikes not coming with tip over / drop sensors. Is this still true with the 2012 bikes?
I ordered a sensor, but then read somewhere that it's now standard equipment on new bikes. I'm not at home to check if my bike already has it or not.
Reject is offline   Reply With Quote
Old 11-10-2012, 12:33 AM   #2 (permalink)
SwaggerJacker's Avatar
The 12 models do have the drop sensor.
Steve
2012 BMW S1000RR
2011 Ducati 848 Evo Stealth (Selling)
2009 Suzuki GSX 650-F (Sold(First Bike)
SwaggerJacker is offline   Reply With Quote
Old 11-10-2012, 02:20 AM   #3 (permalink)
Moontanning's Avatar
Forgive my ignorance, but what does the sensor do when it senses a drop?
Moontanning is offline   Reply With Quote
Old 11-10-2012, 02:40 AM   #4 (permalink)
Aaron's Avatar
I imagine it cuts fuel and ignition.
Get a friend or two, and with the bike idling tilt it over until something is about to hit the ground and see if the bike dies.
2013 S1000RR
Aaron is offline   Reply With Quote
Old 11-10-2012, 03:16 AM   #5 (permalink)
Ahh that makes sense!
Old 11-10-2012, 08:53 AM   #6 (permalink)
The first series of 2010 S1KRR's did not have the drop sensor as a standard installation (which almost all other manufacturers provided as standard equipment). BMW was expecting you to pony up another $100 to purchase one and then pay the dealership for install. People were dropping there bikes, the engine would keep running since their wasn't a drop sensor to kill the engine. The engines would starve themselves of oil and have to be repaired/replaced. BMW finally came to their senses and started installing the sensors in 2010s alongside of a recall on 2010's without the drop sensor pre-installed. Since then every model year has included the drop sensor.
Rob
RobCO is offline   Reply With Quote
Old 11-10-2012, 09:22 AM   #7 (permalink)
Cool, thanks everyone. That's 130 dollars saved.
Old 11-10-2012, 09:57 AM   #8 (permalink)
kismetcapitan's Avatar
I tipped over my '12 - lost balance when I came to a sudden stop in a parking garage. I held onto the bike but all I could do was slow its fall and lay it down as gently as I could manage. It came to rest on the frame slider...and two seconds later, the engine shut off.
Yep, the drop sensor is there.
2000 Ducati ST4 Desmodromico
2010 S1000RR (sold)
2007 F800S (sold)
Old 11-10-2012, 12:29 PM   #9 (permalink)
Although the original connector is still on the wiring loom it is no longer used.
It is now integrated into the system being controlled by the gyro sensor.
Old 11-10-2012, 03:42 PM   #10 (permalink)
Thanks, just got a refund.
