I have read all the posts and threads on this ticking noise from the engine. A lot of horror stories indeed. it's got me seriously worried that out of the only 3 BMW Dealers in my area that they are going to just be lazy and not investigate it properly and worse still, tell me its normal.
After my 1st service it got louder, I'm on 6,500ish kms. The ticking sound is unbearable and embarrassing now, i also knew since my 14RR that these BMW's were loud mechanically and accepted it. At the time knowing that those front butterfly valves are probably mostly responsible for the most part.
But now my 15RR is sounding like a time bomb. Much worse than my 14RR ever sounded.
I have been riding around testing it and trying to figure out where exactly its coming from. I have removed both side and belly fairings to expose the ticking sound better.
I know it can be either one or more of these following problems:
1) Exhaust Header Butterfly Valve in the balance pipe.
2) CCT - Hydraulic Cam Chain Tensioner.
3) CAM and Rockers on the intake side.
4) Clutch Rattle.
5) Valve Clearance.
At around 3,000rpm the sound is very loud.
When I pull the clutch in and play with the throttle gently and hold it on about 3,000rpm the sound is there getting faster and slower with rpm. You can hear it good even when the bike is in neutral in my shed by holding the rpm around or on 3,000rpm.
Sounds to me like a combination of that front exhaust valve and the cam adjuster side.
The worrying thing is that the engine is idling a bit rough and is not as smooth as it use to be from new. Something is seriously wrong and getting worse i just know it.
My worry is that when I take it into the dealer, they are going to do nothing to help me. It's still under warranty and I want them to check out the Cam and if possible replace the exhaust headers and cam chain plug.
Some guys on here complain about the ticking even after they have installed a whole exhaust system, which for them would rule out that annoying front butterfly valve.
I should not have to be outta pocket for any of this mess, but am also worried the dealer/stealer will try and make me pay for inspecting it.
I read a post about a guy having his exhaust headers replaced by BMW Australia.
I have found on the forum that BMW have replaced the Timing Chain With a modified screw plug.
PUMA - 54380454
PART No. 11318534849
I believe I need that part. I don't want to put in a manual plug. the new plug sticks out further in its resting place than the stock oem plug. I guess its kinda like adjusting a manual plug so that it puts more force on the cam chain.
I imagine most members are fairly up to date with this annoying ticking sound as this forum alone has educated me above the so called BMW mechanics, so it seems at times. They seem to just go to work and clock off at the end of the day, its just a job to them is my personal impression. In other words they don't care and they make that pretty clear in their demeaner.
Some of these BMW managers are just as bad if not worse. They seem to play dumb and hope you go away. i have had a few run-ins with these morons.
I have to book my bike in for this inspection on Tuesday but have already been told by a salesman that they won't see it for a week or more at Daisy Hill as they are busy, I went there Yesterday to ask to start-up and listen to some S1's so I could compare the sound to mine, but they had sold them all bar one new 16RR - which sounds smooth as silk as its got like next to zero kms on it. mine was as smooth new to.
I've had the bike for about 5 months from new and it is stock. I got the HP wheels and the special white/blue paint job, I paid $27,000 for it. I'm sick with worry I have a lemon and that no one is going to help me.
I'm leaving the fairings off it so they can hear it better when I finally get it booked in. I can't ride it and won't until its fixed. All my money goes into paying this thing off, as at the time of purchase I believed in the brand. now after educating myself and reading so many peoples stories revolving around this ticking sound I'm sick with worry for good reason.
It seems that some people in different parts of the world get looked after at some dealers while others get done dry by other dealers. This is so WRONG of BMW to allow this to happen to so many while only a few get it resolved.
It seems that so many dealers are lacking the education and the up to date recalls and so on within their systems.
I don't want to be another soul like Macca whose engine blew up. we both bought from the same dealer.
So who has any FRESH news about this serious ongoing issue with these bikes of ours.
Come on BMW look after US ALL.
4) Clutch Rattle.
5) Valve Clearance.
PUMA - 54380454
