GoPro vs Xdreme (review of Xdreme Camera) - BMW S1000RR Forums: BMW Sportbike Forum
Old 08-08-2012, 12:48 PM   #1 (permalink)
Default GoPro vs Xdreme (review of Xdreme Camera)
I put this on another forum, but thought it may be of interest over here too. I was running a GoPro for track use and recently encountered a problem with it, after going back and forth with GoPro (including all the way up the ladder to the owner's wife) I've concluded that GoPro's customer service has gone to shitt and they appear to have forgotten the little guys that helped them get to where they are today... So I went on a mission trying to find an economical alternative to the (IMO) overpriced GoPro.
So I ordered an Xdreme 1080P camera and got it earlier this week. I haven't had a chance to try it on the bike at the track yet, but have played around with it at home and have it mounted and ready for this weekend's races.
Here's my preliminary feedback and comparison to the GoPro HD Hero:
---------From another forum I posted on----------
Well, got my Xdreme 1080P camera in the mail yesterday (from Hong Kong). Of course the GoPro is made over there (China) too... Haven't had a chance to use it on the track, but here's my initial feedback (compared to GoPro) based on the limited time I've spent playing:
  • Menu - MUCH easier with the Xdreme... MUCH MUCH!!
  • Ease of use to record, know you're recording, and know what you're recording - MUCH easier with the Xdreme... MUCH MUCH!! (has the little LCD screen in the back).
  • Video... although I haven't compared them side by side... I would say they are VERY close in performance.
  • Recording Sound... both are waterproof cameras so both to a degree suck as far as sound. That said for motorcycle use, both are just fine and there is not a clear winner. The Xdreme seemed to pick up voice better, but the GoPro seemed to pick up the sound of the motorcycle better (but not voice). The Xdreme also comes with an external mic if you want to use it (it also has it's own internal one). But to use it, you have to have the rear door open, which isn't ideal... but then again, it's all the waterproof stuff that is the causing that to be.
  • Battery life - unknown at this point, but they advertise similar run times. However, a major difference is in fact that the battery the Xdreme uses is NOT a proprietary one and is used in many cameras and is easily come by (and cheaper).
  • Mounting options - GoPro clearly has more mounting options... that said, the Xdreme had what I needed and the camera itself comes with the female tripod threaded hole which worked quite well for how mine is mounted.
  • Cost - No brainer here... ~$140 vs. $300 (think I'll buy more track time!)
--------------Here's some specs and pics----------------
  • Screen: 1.5 inch TFT Screen
  • Sensor: 5 Mega 1/2.5 CMOS
  • Still Image Resolution: 3M(2048*1536), 5M (2592*1944), 8M(3200*2400), 12M(4000*3000), 16M(4608*3456)
  • Video Resolution:
    - FULL HD (1920*1080) 25/30FPS
    - 1080P (1440*1080) 25/30FPS
    - 720P (1280*720) 60FPS/50FPS/30FPS/25FPS
    - WVGA (848*480) 60FPS/30FPS
    - Digital zoom: 4x
  • Video output: PAL/NTSC/HDMI output
  • Audio: Built-in microphone/External microphone/speaker
  • Storage: SD card slot, support SDHC card (up to 32G)
  • Lens:
    - 142 degree(1080P);
    - 172 degree(720P&WVGA)
  • File format: JPEG/MOV
  • Power: High–capacity Rechargeable Li-on battery 3.7V/1800mAh
  • Port: Mini USB2.0 port /TV OUT/HDMI
  • Waterproof: Yes (IP68)
  • Language: English, Chinese, Spanish
  • Dimensions(mm): 104 (L) x 58 (W) x 50 (D)
  • Certification: CE, FCC, RoHS
__________________________
Old 08-08-2012, 05:23 PM   #2 (permalink)
BMW1000's Avatar
Thanks for the write up comparison. Likely ordering one shortly to give it a go as well. If I can get it before hitting the track I might even be able to post video comparo with the go pro as that is what I run on my CBR and can put this one on my S1K. For the price its worth a try. Cheers.
BMW1000 is offline   Reply With Quote
Old 08-08-2012, 05:46 PM   #3 (permalink)
Boarider's Avatar
Just throwing it out there but I use a Contour GPS that I like.
Sent from my MB860 using Motorcycle.com Free App
Boarider is online now   Reply With Quote
Old 08-08-2012, 05:48 PM   #4 (permalink)
joew4505's Avatar
I would be curious to see how you mounted this. Any chance you can take a pic of the setup?
joew4505 is offline   Reply With Quote
Old 08-08-2012, 06:11 PM   #5 (permalink)
I'll snap a picture of mine in about an hour when I get home and post it up. Mine is a bit of a custom mount deal though that I fabbed up from some other mount I had laying around.
My ZX6R has a mount on the top triple for an Ohlins damper (stock), I am using a GPR so I had a threaded nipple (if you will) that I could attach my mount to... so that's what you'll be seeing. I'll get some pics up shortly.
Old 08-08-2012, 06:13 PM   #6 (permalink)
kautiongsr's Avatar
Yup that's what I use also love it
Sent from my iPhone using MO Free
Auto techinteriors
Big Daddy Julio
kautiongsr is offline   Reply With Quote
Old 08-08-2012, 07:02 PM   #7 (permalink)
Here's some pics... My main goal, since this is on my race bike, is to be able to record my RPMs around the track so I can review after the races to see what changes (sprockets/gear selection) I might need. It also picks up my gear indicator on the dash, but that is less important. The bolt holding the camera to the mount (5th picture) bolts into the receiving end on the camera that accepts all standard tripod type bolts you find on a tripod for cameras, etc.
GoPro vs Xdreme (review of Xdreme Camera)-dsc_0216.jpg   GoPro vs Xdreme (review of Xdreme Camera)-dsc_0211.jpg   GoPro vs Xdreme (review of Xdreme Camera)-dsc_0213.jpg   GoPro vs Xdreme (review of Xdreme Camera)-dsc_0222.jpg   GoPro vs Xdreme (review of Xdreme Camera)-dsc_0220.jpg
Old 08-08-2012, 07:04 PM   #8 (permalink)
A couple more...
GoPro vs Xdreme (review of Xdreme Camera)-dsc_0217.jpg   GoPro vs Xdreme (review of Xdreme Camera)-dsc_0214.jpg
Old 08-08-2012, 10:34 PM   #9 (permalink)
Thugsfatboy's Avatar
Good info ,i have used a Contour but it seemed to have issues and i got tired of it not working,i bought the Gopro and setup is a bit of a pain,i use these to check my lines etc at the track,not so much rpm gear etc as i am very limited in tracks,and its only 2.5 k long so long
have you tried Dashware software for your vids a mate showed me some footage with laptimer etc overlaid
Old 08-08-2012, 11:16 PM   #10 (permalink)
adamv1000's Avatar
Does it have Suction cap so you can stick it to your fairing?.
adamv1000 is online now   Reply With Quote
